80 mph at 3000 rpm's good?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chaka454, Apr 17, 2002.
  1. chaka454
    chaka454 1/2 ton status
    Nov 13, 2001
    199
    California
    80 mph at 3000 rpm\'s good?
    Am I running too high RPM'S I'm doing 80mph at 3000rpm's is this good? I'm running 35's with 410's and a 4" lift, I was driving my moms 2000 Tundra with over drive I was going 80 and took the overdrive off and it jumped from 2800rpm's to 38 almost 3900rpm's so that leads me to believe that I'm not too bad what do you guys think?
  2. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Re: 80 mph at 3000 rpm\'s good?
    3000 rpm cruising speed for a truck small block 350 is about the limit if you want it to last a while...the Tundra's overhead-cam, high tech motor is a higher revving motor than your 350. A constant 3000 rpm seems a bit high to me...and of course I don't drive the big behemoth at 80 mph either! That would get scary in a hurry! /forums/images/icons/smile.gif
    When towing, and in Drive (not Overdrive), I try to keep the revs in the 2600-2900 range at the most (about 65 mph or so)...
  3. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    That's about the right speed where my truck just begins to smooth out. (Well my speedo says like 90 something since it isn't accurate) but my RPM's are only about 2700. And it feels like glass at that speed. When I go any slower I feel/hear all kinds of WIERD noises and vibrations. Anything below 65 and above 80 is good for me./forums/images/icons/wink.gif
  4. wheelnut46
    wheelnut46 1/2 ton status
    Nov 27, 2001
    122
    Rhode Island
    55-65 is about it for me. I can watch the gas guage move at 65+. I havent seen 80 mph is a LONG time.
  5. barbastard
    barbastard 1/2 ton status
    Dec 7, 2001
    289
    Pleasant Hill, California
    I've got 36's with 4.56 and NO OVERDRIVE (thanks to my TH350) and I turn about 3000 doing "cruising speed" on the freeway. I haven't yet determined what exact speed I'm at due to my speedo being way off...it says I'm going about 85-90. However....if that's the case....I've never been passed so much doing "90". I estimate I'm doing about 60, maybe 65. I'm really not going to be able to cruise much past that though...the little 350 wouldn't like it. It's going to make those long drives to the mountains a LOT longer!!! You didn't mention what tranny you've got...I'd be curious. But it sounds like your RPM is just about right.
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I would say that you want your normal cruise speed to fall into the lower end of your powerband. This will be your call because you know the specs of your engine. I cruise at 2200 doing 65-70 (with 44's, 4.10s, SM465). I plan to go lower on the gears one day. To me, I sounds like your speed / RPM is fine....especially considering the hassle to change anything.
  7. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    3000 rpm's at 80 is not bad. I have 4:56's and 35's but hardly ever get into overdrive.
  8. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    barbastard. Just a thought. Your spedometer will be off when you get larger tires and do not re-gear your truck. However, 36" tires and 4.56 gears is about the same as stock tire to gear ratio (right??) so your spedometer should be pretty accurate within a few mph I would think. If you dont have one, find a buddy with a GPS and check your speed with that, works great.
  9. chaka454
    Nov 13, 2001
    199
    California
    I have a TH350, hmmmmmm I guess i'm gonna try to keep it under 2800 just to be on the safe side, thanks for the info.
  10. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Well my Jimmy has 35s(really measure 34") 4.56s and I have OD. I am around 2600 rpms at 80 mph. There is nothing wrong going over 80 in a big truck /forums/images/icons/smile.gif
  11. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    3000 for me is 72-73 mph with 31's SM465 and 3.08's in the rear. I'd like my 3000 to be about 80! I like to keep my motor around 2800...I'd think long drives at anything between 2600-3200 won't kill a 350 anytime prematurely.
  12. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Theoretically, 4.56's and 35/36's is close to stock. So are 4.11's and 33's...Thats what I have, and mine is way off...says 25 when going 20, so about 50 when goiung 40, if it went to 100, I'd be going 80. I've had the needle buried and looked at the speedometer on newer Suburbans and stuff, because I know where all the numbers are on the gauge, and they usually say something in the 70's. If you actually do the math, 3.73 is closer to stock for 33's and 4.11's for 35's.
  13. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    3000 is what i hit when cruising around 65, that's in drive. with the overdrive i'm at about 2400 to 2500. that's with 5.13s and 39'' boggers.
    ric
  14. Jay73K20
    Jay73K20 Registered Member
    Mar 4, 2002
    67
    If you do the math, take your known values which is 3000 rpm, 4.10 gearing, 1:1 transmission gear, 35" tire and 5280 feet is one mile. (3000/4.10=731.71 rpm for the axles) (35*3.14=109.9 circumference in inches) (109.9*731.71=80414.93 inches per minute) (80414.93/12=6701.24 feet per minute) (6701.24/5280=1.27 miles per minute) (1.27*60=76.2 miles per hour). If you had a lockup converter that was locked up at the time you took the reading like a TH350C or a manual transmission then the answer would be accurate. If you don't have a lockup converter then you have to account for converter slop, which could be 10 to 15 percent. So 3000 engine rpm which is felt on the torque converter would only equal 2550-2700 driveshaft rpm. Conclusion, you are not doing 80 MPH at 3000 RPM with those components that you mentioned.
