80' or 84'???
Discussion in 'The Garage' started by theitalian404, Oct 30, 2005.
  1. theitalian404
    theitalian404 Registered Member
    May 7, 2005
    75
    Georgia.
    Hi. Im so pumped!!! I have a choice of getting a 1980 K-10, 350, automatic, no rust, average paint job, bent up front bumper..working conditon for $1800. Or a 1984 K-10, with a 88' front end, 350, 4-speed, Horribly faded paint job, no mirrors for $1600. what would ya'll choose? any difference in suspension from 80 - 84?? all replies/comments welcomed!
    thanks,
    anthony.
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Shouldn't be any difference in suspension. The axles might be different but I don't know the years well enough to tell you for sure.
    As for your choice, it depends on what you intend to use this truck for. As a DD it might be nice to have an auto...whereas for a wheeler the manual would be hard to beat for durability.
    Any more specifics on the trucks or their intended usage?
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    they should have the same suspention, but they may have different number of leaves depending on options.
    the 80 would have (if original) a th350 with a slip yoke np205 tcase with a 10 bolt front and 12 bolt rear.
    the 84 would have (again if original) a 305, sm465/np208, mechanical clutch, with 1350 ujiont. 10 bolt front and 10 bolt rear.
    personally i would get the 84, mainly because of the 4 speed, i also perfer the newer front end. mirrors are nothing and a dozen cans of rustolium and it'll look better than now.
  4. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    i still wish i would have gone with a manual instead of the automatic k5 that i have. but i would check out the electrical and the injection on both and go from there. you dont want to deal with something that will cause major problems for you in the future. what are your plans for it?
  5. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    1980 came out with an NP205? I thought they quit using them about 75 in the 1/2 tons?
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the np203 stopped in 79 and the np208 started in 81, the only tcase available was the np205. in 80 the np205 started the slip yoke on the tcase.
  7. theitalian404
    May 7, 2005
    75
    Georgia.
    Hi, it wouldn't be a dd until May of 05'-that's when I get my liscense. Until then me and my buddies will be wrenching on it, and taking it on private trails. Im sure my father would go ahead an get it insured, and registered, as he did with my S-10 Blazer. But yes, when I get my liscense it will be a daily driver, and weekend rig. And yes, they both have the original transmissions. Yeah-im going for the manual as well! My S-10 was a automatic..and I hated it. I do intend to drive it hard on the trails, and mild mud. I plan on 35's and im thinking a 4 inch lift...and sawzall! :D :bow: Also, lockers front and rear. The only thing im giving up for this truck is my Fourwheeler, which I think is a more mature choice...i'd rather have a 4x4, than a racing fourwheeler, and no rig at all...right?
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    That may be what GM states but that is not always the truth. A good friend of mine Matt (az-k5) has a 1980 K5. It should have had a 205 but it didn't. It had the 203 in it. Most 1980 K5's probably had the 205 but some take it for granted.
    I personally would go with the 4speed/208 truck. The combo offers alot lower gearing and is probably the better plateform for a buildup. That is especially true if you want the 4 speed. 4speeds in K5's are not the most common and have a certain cool factor in my book.
    Harley
  9. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    4in lift and 35s... probably wouldn't only have to do minor trimming to your front fenders
  10. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    Get the SM465 manual. It's the best, and indestructible. Plus you can always find a NP205 from earlier years to put in it (my '79 w/ SM465 has the NP205, I'm not sure when they stopped using them in this combo). That's the ultimate grenade-proof setup. I run 40" Boggers (19.5 inches wide) and this combo doesn't even flinch.
  11. MrArmyAnt
    MrArmyAnt 1/2 ton status
    Dec 29, 2004
    662
    Texas, Kick a$$! (Grapevine, DFW; also Norman, OK)
    So ya'll prefer manuals on the trail? I thought dealing with clutch in mud would have been a hastle.
  12. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Mud would be the only place it MAY become troublesome. On trails you can't beat it. A nice addition is a hand throttle on the shifter. You can get a kit from Rubicon Express for like $30, or you can make your own from a bicycle shifter. Then you can clutch, brake, and gas all at once! (Also very excellent if you like LSDs). I still prefer the manual, hands down.
  13. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    Go with the '84. I have an '80 k10 and the thing is a nightmare because 1980 was an inbetween year for the trucks. You'll find that some parts are year specific, some are 80 and older, and some are 80 and newer. It's a hassle.
    I prefer manual transmissions. But I also like the np205's near indestructability. However the np208 also has a better low gear.
    Just some things to think about.
