8000 lb winch...enuff?
Discussion in 'The Garage' started by jekbrown, Sep 12, 2003.
  1. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    if you were running a k5 that had just a s-10 cab, small block, chopped frame/tube rear etc (thinking 4500-4800 lb range here), would a 8000 lb winch be enough?
    j
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes but i would still get a snatch block /forums/images/graemlins/thumb.gif
  4. muddinmike
    muddinmike Registered Member
    Jan 7, 2002
    30
    Boise ID
    Enough for what? Rockcrawling? you betcha! Stuck in the mud up past the frame? not even close to moving you! I would say for general use your probbaly allright with a 8000 pounder but it sure wouldnt hurt to go bigger. And yeah a snatch block sure would help either way.
  5. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    yeah, i have never wanted to run in mud... and if I ever got stuck up to the frame, Im grabbing a shovel first, not a winch remote. This rig would be for trails and rocks.... and I'd definitely have a snatch block to 2x the winches power for really nasty stuck situations or when i was helping pull someone else's heavy rig out. anyway, thanks much for the input guys. Im not rich, and I always seem to find great deals on 8000 lb warns... prolly cause everyone needs/wants a 9000 or 9500. /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
    j
  6. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Rule of thumb is multiply the fully loaded trail weight of your rig by 1.5 and that is the size winch you should get. You can fudge this a bit with a snatch block but you cut your cable length in half. I would say for you a 8,000lb winch should be fine even without a snatch block as 5,000 x 1.5 = 7,500 which is well in line with what you have and plan to get.
  7. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I always find it worrysome when people put up posts about being stuck up to the frame, and after mega broken parts, 3 winches, 4 trucks, they had to call in a back hoe or something...
    I have been stuck to the frame before, but I think a 2000lb winch probably could have moved me out. I've never tried that theory, but...
    I estimated my rig to weigh in at approximate 6200 Lbs with all my gear and people weight. applying the standard acceptable 1.5x , I would get 9300. To keep it save, I got a 10.5, and a snatch. Seeing as how I cant trust those little jeeps to get me out. /forums/images/graemlins/smile.gif
