8000lb winch enouugh??
Discussion in 'The Garage' started by buffcc1, Jul 5, 2006.
  1. buffcc1
    buffcc1 Registered Member
    May 30, 2005
    42
    Wichita Falls Texas
    Is an 8000lbs winch enough for a K5
  2. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    General rule is 2x the weight of your rig which is gonna be about 10k or 11k. But my bro ran around with a 2000lb atv winch for his s10 4 door jimmy and it got him out of some mud.... just depends on how hard you get her stuck.
  3. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    If its a Ramsey or warn, yes. If its something else, no.
    Actually if you use a snatch block, an 8000 lbs winch can get you out of almost anything...A snatch block doubles the pull rating of your winch.
  4. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    X2...........I've used a 8000 lb Warn for ten years now. Never a problem with some badly stuck situations. I always have a snatch block with me though, just in case.
  5. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    The general consensus around here is "No, unless it's a Warn 8274"
  6. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    That makes no sense at all.
    An 8000 lbs winch is rated to pull 8000 whether its an 8274 or Ramsey 8000 or a warn m8000. Actually, the 8274 will fry its solenoids quicker than the other two listed due to such a high amp draw at full load...
  7. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    if you can afford a bigger winch get it. but 8,000lbs(or 16K if doubled) of pull will still work in most situations.
  8. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    It does make sense.
    The 8274 is rated to pull 8000lb at a given minimum line speed, with almost all other 8000lb winches the the 8000lb rating is the stall load.
    So, the 8274 will actually pull over 8000lb and most others will actually pull less than 8000lb.
  9. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    I don't agree with your statement.
    All warn and Ramsey have a line speed rating at full load like almost all winches on the market. If a winch stalls at full load, wouldn't the line speed be ZERO?
    The 8274 has a line speed of 6.1 fpm at 450 amps.
    The warn m8000 has a line speed of 8.0 fpm at 435 amps.
    The Ramsey Profile 8000 has a line speed of 8.0 fpm at 420 amps.
    So the 8274 is the slowest at full load and draws the most amps...
  10. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I know I have pulled over 9500 lbs with my 9500Ti. It got hot a few times and had to let it rest, but never stalled:D :bow:
    Super Duty CC long bed Dually 4x4 Powerstroke uphill in the sand. If he tried to help it just dug so he kept it in neutral. I had to bury my K5 to the axles:D
  11. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    Can someone explain how the 8274 and 8274-50 are both rated at 8k when they both have the same gear-set, but the motor on the -50 has almost twice the HP?
    Oh, and I've got an 8274-50 and an XD9000. I like the 8274 better, but either will pull my Jimmy.
  12. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    One small, but very important, detail about this. The pulling force is only doubled if you connect the line back to the truck. Connecting to something else (tree, another truck, etc) will only cause a change of direction.
  13. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Here is what my 8000# warn did:D
    If you look in the second pic he is moving forward and I am pulling him to the side to get him back around the corner:D .
    Ira
  14. loafer
    Aug 19, 2003
    634
    Lyman, Maine
    HP is just work/unit time (1HP = 550 lb-ft/s). So the new motor spins faster, but generates about the same peek torque, therefore generating more HP (the rate at which work is done is faster) This translates into higher line speed however, the max line tension is only dependent on the torque the motor can generate, so it stays about the same.
    Make any sense?
  15. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    8274's advantage is that it has fast no load line speed and the motor and rope are isolated so heat isn't an issue when using rope. They have also proved to be very reliable over the years. Good winch. They get used a lot in jungle/expedition comps and stuff from what I have seen... that should tell a perspective buyer something. Comp guys tend not to use junk.
    j
  16. bigjbear
    Feb 18, 2000
    13,970
    450
    Marietta GA
    Yeah, I forgot to take motor speed into account-I assumed it would not have changed.
