81 1 ton truck
Discussion in 'The Garage' started by Z3PR, Dec 7, 2003.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I may have found my donor truck. Haven't seen it yet, but got a email from a guy with a 81 1 ton truck. (In need of help) What would it have for motor, transmission, transfer case, and gears ???
  2. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    either a sm465/205 or 400/205. Engine could be anything straight 6/350/454. Gears most often 410 or 373. No way of telling without looking at it /forums/images/graemlins/thumb.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    1 ton what? Chevy? Ford? Dodge?
    Assuming Chevy as this is a Chevy site...
    Automatic? Manual?
    Ok, we're still assuming. It most likely has a 350 in it. I wouldn't say that it'd be impossible to have an inline six cylinder, but it's very unlikely. It could have a 454 too. I don't believe the 6.2 was available until 82, so it's most definitely gas.
    Transmissions...two options TH 400 or SM 465
    Transfer case, most likely an NP 205
    Front axle, definitely a D60 with most likely 4.10 gears
    Rear axle, 14 bolt full floater, most likely 4.10s again with or without a Gov lock
    Most likely a single piece front shaft with a 1310 u joint, a 1330 CV, and a rear two piece shaft with all 1350s.
    That's assuming it's not a Dodge, Ford, or God only knows what else could be referred to as an "81 1 ton truck" that could be a 3/4 ton for all you know.
  4. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    like was stated, however a general rule of thumb with 1 tons is the smaller the engine the lower the gears. 90% of small block 1 ton's have 4.56's and 90% of big blocks came with 4.10's. /forums/images/graemlins/thumb.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I guess both of my 1 tons are in that 10% range, because both of my 1 tons have 4.10 gears and both had 350s from the factory. What a crock.
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Why wouldn't it have a NP 208? 81 was the intro year for that T-case and it was used in the CUCV's...
    Gearing...I'd guess 4.10's unless it had a straight 6 in it.
    Rene
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i had a 76 1 ton it was 4.10 with 350 engine
    hope you get the 1 ton /forums/images/graemlins/laugh.gif
    for 81 K30 regular cab all states cept cali:
    L25 292 engine, MM4 and MX1 trannies, axles: GQ1 4.56 and no optional ratios available for this combo, 9200GVW
    LT9 5.7L engine, MM4 and MX1 trannies, axles: GQ1 4.10 and HC4 4.56 optional, 9200lb GVW
    LT9 5.7L engine, MM4 and MX1 trannies, axles: GT5 4.10 optional and GQ1 4.56, 10,000lb GVW and locking diff not available
    LE8 7.4L engine, MM4 and MX1 trannies, 3.73 GQ1 and GT5 4.10 optional and HC4 4.56 optional, 9200lb GVw
    LE8 5.7L engine, MM$ and MX1 trannies, GQ1 3.73 and GT5 4.10 and HC4 4.56, 10,000lb GVW and locking diff not available
    GQ1 means standard ratio for that engine and tranny, any other axle ratio RPO other than GQ1 is optional ratio RPO code
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    guess my d60 donor was in the 10% as well. 4.10s and a small block.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I don't know why the CUCVs used NP 208s. I know my 1 ton had an NP 205, and so has every other one I've seen besides the military ones. Seen plenty of K20s with 400/208 combos, but I've yet to see a K30 set up that way.
  10. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    How odd, you'd think the military would spec the 205 and GM would give all the civi's the less stout 208.
    I was just kind of curious about that...the only K30 I've ever seen was Wes's about 2 years ago.
    Rene
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not all CUCVs have the NP 208. I know what you're saying though, makes no sense to me at all. You'd think that the military would want a tougher rig, but they are mostly 208s. Who knows, maybe they wanted the better low range or something.
  12. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Why ofcorse it's a Chevy. I wouldn't have any use for something else.
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I was simply trying to explain how vauge your post was.
  14. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    .......and VAGUE too. /forums/images/graemlins/rolleyes.gif
  15. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    hehehe
  16. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Okay, found out it has a 454, sm465/NP205, and 4:56 gears. Now I'm getting more and more intrested in swaping the whole drive train into the K5. I could handle a 454 under the hood. Yep, might just have to do it. Still waiting on pics and a price.
  17. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    And just when do you plan on doing all that swapping over. /forums/images/graemlins/thinking.gif Just how long have you had those 3/4 ton axles sitting in front of your truck? /forums/images/graemlins/deal.gif /forums/images/graemlins/ignore.gif /forums/images/graemlins/thumb.gif
  18. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Those are in a garage. I've been in no hurry becouse I've been hunting a Dana 60. This K30 parts truck is becoming too good of a deal to pass up on. 454, sm465/NP205, and 4:56 gears. When would I do the swap, whenever I get around to it. I try not to get in a hurry over anything, couse when I do, everything gets all f_cked every time, LOL.
    /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  19. heavy4x4
    Aug 28, 2002
    3,270
    Tell me about it. LOL, been there done that...still haven't learned my lesson. /forums/images/graemlins/tongue.gif /forums/images/graemlins/rotfl.gif
  20. the cork
    the cork 1/2 ton status
    Apr 20, 2003
    128
    mid west,
    looks like you hit the jackpot on all the junkyard jewels all at once,
    what price are you looking at, i found a similar truck,
    but the guy wanted 6 grand, so had to pass on it, /forums/images/graemlins/eek.gif
    hell at that rate might as well go to dynotrac,
