81-87 4 core radiator cushions ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Dec 12, 2002.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    where do we get four core radiator cushions from for the 81-87 trucks ? i need some for the four core radiator i need to put in the 81 since i am done swapping in the 350 and headers with 2.5" straights and just working on little stuff on it today to get it fired up, figured i could cut bottom cushions ends off and top ones i dunno yet,.
    thanks for anything
  2. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    A salvage yard should be full of them.
    I think I saw them at Pep Boys in the common replacement parts section. You know, the stuff in the red packaging like dome lights, window switches, etc...
  3. dyeager535
    26,980
    GM should be able to get them for you as well, but be aware that the upper radiator mounts are different too on the wider radiator. You can modify the smaller ones, but I'd prefer ones that "look" right.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    tried GM first thing this morning and their puter shows all being same 81-up 5-30 series, which is impossible but is what puter shows..,.
    hmmm.....
  5. dyeager535
    26,980
    Yeah, they are smoking crack. There are at least three different "mounts".
    I've got the "tall" style, but a two core radiator. There are the "short" ones that accomodate a radiator about 2" "shorter" than the "typical" V8 radiator, and then there are the large ones, same height as the typical V8 ones, but wider for the four rows.
    I should take my parts manual to work with me /forums/images/graemlins/smile.gif
    Did you ask for a BBC radiator mount in something like an '85 1 ton?
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    he said all same 81-87 no matter the truck,
  7. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    just take a die grinder to the smaller ones , <carefully> i put a 4 core in my truck with the crate engine and didnt think it would fit but it does and you cant even tell unless you really look hard .
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you can tell this 4 core was "coaxed" to fit cuz of the modified upper brackets, hehe
    what year is your rad support ?
  9. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    mine is an 81 single headlight . but now it is severly modified on the outside ends /forums/images/graemlins/thumb.gif
  10. dyeager535
    26,980
    0wn3d! Lol, don't get to use that enough here, just had to.
    Looking at my 85-86 parts manual, and running them through www.gmpartsdirect.com I found a few different part numbers for you to try, or have him look up.
    I'm no wiz with the parts catalog, but here goes in group 1.270:
    CK 1/2/3 6.2 bracket, (rad mt upr) 14039949LH, '50 RH
    CK 1/2 4.3 (insulator, rad mt) 14066041
    CK 1/2/3 292 W/O AC (insulator, rad mt) 51.82MM cut out, lwr 14032841
    CK 2/3 292 350L,M (insulator, rad mt) 51.82mm cutout 14063126
    C 2 454 w/MT(M20) w/o AC (insulator, rad mt) 48.78 cutout
    14018568
    CK 1/2/3 292, 305H, 350L, M (Pad, rad ret) 51.82MM cutout
    14018584
    CK 1/2/3 454, 6.2 (pad, rad ret) 78.3 MM cutout
    6264100
    CK 1/2/3 6.2C, J (panel, rad upr mt) 14039948
    CK 2/3 292 w/o ac (panel, rad upr mt) 14022775
    C 2/3 454 (panel, rad upr mt) 14018600
