81 Blazer calipers on a 73 K20
Discussion in 'The Garage' started by trailblazr81, Jun 28, 2005.
  1. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    I have couple year old calipers on a 81 Blazer thats dead. Can I put those on my 73 K20?? Or would the older 3/4 ton 8 lug have different calipers?
  2. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    the bolt that holds the break line to the caliper (i think its called the banjo bolt)is diffferant. the blazer calipers have a 10mm banjo bolt and the k20 has 7/16's
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    But you can use the brake line off the '81 with the calipers and banjo bolt from the '81 and it will work perfect on your '73 :thumb:
  4. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    well it has steel braided lines so the lines are being swapped as well!!!
