81 burb rear end to a 72 jimmy?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by hjalbert3, May 6, 2004.
  1. hjalbert3
    hjalbert3 Registered Member
    Apr 30, 2004
    6
    anyone know if a 1/2 ton 4x4 81 burb rear end will fit a 72 jimmy 4x4 ? Im wondering about the spring perches and the shock mounts. the ratios are the same, and they are both 12 bolts, thanks hj
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Not without some modification. The '81 axle has shock tabs that are on opposite sides. The shocks on your '72 both mount on the front of the axle. The spacing is different too.
    The spring perches are different as well. The '81 axle will have a center to center distance of 42.5" Your '72's distance is 40". Time to break out the torch and welder. /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/waytogo.gif
  3. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Also wouldnt the 81 Burb rear diff be a 10 bolt?
    BTW a 2nd Gen SRW 1 ton will bolt right in but you will have to still move the one shock mount to the front of the axle tube /forums/images/graemlins/thumb.gif
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    GM started to phase out the 12b rears in early 80's so you could see a '80 with a 10b rear or a '84 with a 12b rear. There wasn't a clear cut date when they switched over...
  5. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Very rare for a 12bolt after 81 though /forums/images/graemlins/k5.gif
