81 or so Ch465 crossmember ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Nov 24, 2002.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ok,. refresh memory time:
    how is 2wd 4 speed CH465 tranny supporets in 81 or so year, do they use front or rear mounted and if rear mounted thne do they use similar x member to auto ones ?
    and do they use aluminum or iron bellhousing ?? pics would be great.
    thanks for anything
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    73-up uses a crossmember under the back of the SM465. They use an aluminum bellhousing too.
    I had a SM465 crossmember from a '79 2wd 1-ton, and it "humps" up on both sides for dual exhaust clearance. The TH400 crossmember in my Burb is definitely not the same.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    there holes in the case at rear extra for this type of mounting ?? i dont see any way on this ch465 out here how it could have a rear member
    hmm..
    thanks
  4. u2slow
    May 9, 2001
    2,217
    BC Canada
    The 73-up SM465's have a different tailhousing. Also, all four holes on the front of the tranny are drilled through - 72-older had the bottom two threaded.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    crappy. case itself is same casting number all years and applications, but apparently tail piece casting change and then the two front holes change, yeah this 68 one(first year for the 465 tranny) does have two threaded and other two not, up front
    thanks for your time and info /forums/images/graemlins/laugh.gif
