81 speedometer still doesnt work
Discussion in 'The Garage' started by R72K5, May 25, 2005.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ok in the 81 the speedometer wasnt working at all so i felt up under dash to speedometer and the cable wasnt on it so i popped it back on it and the speedo still doesnt work and its connected good and tight at the tranny
    any ideas ?
    it is totally dead needle never budges ever
  2. dyeager535
    26,976
    Going to need to check to see if the cable rotates at the speedo end while you drive.
    If it doesn't, broken cable or speedometer drive or driven gears shot.
    If it does, speedometer is toast.
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Is this on a 4x4??
    If so it should go into the back housing on the transfer case, not the tranny.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    nope is 2wd
    i guess i am gonna have to take cable back off speedo back and try to feel it while driving, or pull the cluster and drive then,
    hmm
    thanks
  5. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    I don't know if you're able to do this, but instead of going through the hassle of removing the cable from the speedo could you disconnect it at the tranny and hook it to a drill? Just a thought.
  6. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    That is how I checked mine works good too :waytogo:
    dyeager535 named all the parts involved that could need to be replaced..
    I will give you a hint just because the plastic driven gear doesn't look wore out don't mean it's not... The gear is about $7.00 at the dealer and the cable is about $15.00 At Auto Zone IIRC ...
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    auto zone has specific application cables ? housings too or just cables ?
    interesting
    opk i just went out to truck and got under it and disconnected the cable off the tranny and the cable was slid out of the housing way too far and was kidna jammed wouldnt spin so i finally got it back in right and it spins goods and with my fingers spinning the cable the speedo will jump up to around 35mph
    so thje speedo and cable are good
    but why did the cable slide out of the housing and jam up ?
    isnt there supposed to be an flat end collar or something on the cable to keep the cable in place inside the housing ?
    thanks
  8. mudslinger99
    Oct 8, 2004
    512
    East Coast
    Yes they have both the cable and the outer liner...They matched it up perfect the 1st time too :shocked:
    You can buy just the cable or you can get the cable with the outer liner... The $15.00 I paid for mine came with both but they did have just the cable itself for a few dollars less...
    You can actually undo the clip from the speedometer and from tranny/transfercase and leave the liner connected to the frame and slide the new cable thru it... But There is only a couple clips to mess with to replace the hole thing so that is the way I did mine...
    As for the cable getting jammed up in the housing I'm not sure how that would be possible if it was the correct cable size..
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    hmm
    im confused
    i dunno what the deal is
    guess never will have a speedo in this one
    thanks
