82 350 Motor Manifold Heats up bright ORANGE
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jeepsick, Jan 7, 2003.
  1. jeepsick
    jeepsick Newbie
    Jan 7, 2003
    The passenger side Manifold on my 350 is heating up and about ready to melt after about two hours of driving. The carb is not running too lean. I checked the catylic converter, I torched the heat riser, and plugged all the loose vaccume lines. Is there anything else anyone knows to try? Anyone had this prob before
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Your timing maybe????180 out... /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/deal.gif /forums/images/graemlins/wink.gif
  3. 79Silv4x4
    79Silv4x4 Registered Member
    Aug 14, 2002
    50
    Lawton, OK
    I had the same problem on my '83 and it was timing!
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Retarded timing will do that, but if it is just one side, it is a vacuum leak. Most likely at the intake manifold gasket.
  5. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Only one side, eh?
    Do you still have all the original smog junk on it? If so, is the valve down there by the firewall in the exhaust system opening?
    It might be timing but it sounds like it's either an exhaust or air problem. If you've got a dual plane intake spray some WD-40, carb cleaner, brake cleaner, or windshield washer solvent around the base of the carb on the driver's side. You might be sucking air under the carb.
    Pull out the spark plugs on the passenger side and see if it's just one or two cylinders or all of them.
