'82 Brake upgrade
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cusm, Feb 5, 2003.
  1. Cusm
    Cusm 1/2 ton status
    Feb 25, 2000
    360
    OK
    \'82 Brake upgrade
    I have an '82 that the master cylender is leaking and needs to be replaced. It is a cast MC and I was wanting to know if the newer MC will be an exact replacement, or if the MC and booster would both have to be replaced. Or would I be better off leaving the same and just replacing the original MC with another cast one.
    Also I need new rotors and was wanting to upgrade, what is a good recomendation?
    Thanks, Brian
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    Re: \'82 Brake upgrade
    pretty sure it wont, but its worth a shot to try fitting it,
    rotor upgrade ? all could be done as far as upgrade is swap to 1.25" rotor spindles and some really good pads and/or crossdrilled rotors
    good luck
