82 diesel GMC 1500 pickup
Discussion in 'OffRoad Design' started by Tasheena, Jan 8, 2003.
  1. Tasheena
    Tasheena Newbie
    Jan 7, 2003
    3
    Does anyone know how to air bleed a diesel pickup??? Is there some tip or trick to bleeding the fuel line?? Thanks for your help.
    Tasheena /forums/images/graemlins/truck.gif mga2002@earthlinlk.net
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You might have better luck posting this in the Diesel Forum. There are quite a few tech heads in there.
  3. bigbluek20
    bigbluek20 1/2 ton status
    Dec 18, 2001
    119
    Loveland, Colorado
    Assuming that you are talking about the fuel system, try removing the input line to the injection pump and putting air pressure (from a compressor) to the fuel tank through the filler.
    Worked when I did it on a 6.9 F*rd (disclaimer: wasn't mine /forums/images/graemlins/tongue.gif)
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Make sure your lift pump is good, fill the fuel filters, crack the line at the pump. When it weeps, (during cranking) tighten it up and individually crack the injector lines at the injectors while cranking. You'll probably only have to do part of them since they can bleed themselves if the motor will run. If not, bleed them all to get the air out, then the injectors should start firing with no problems.
