82 K5 Rear End Problem
Discussion in 'The Garage' started by klowninc89, Feb 22, 2010.
  1. klowninc89
    klowninc89 1/2 ton status
    Apr 15, 2009
    117
    ohio
    I have a 10 bolt corp with a gov lock. Chewed up spider gears. The bolt holding the locking pin broke off in carrier. Tried drilling and cannot get it out. Does anyone have any other ideas?? Thanks You MATT
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,632
    5
    Ohio
    I don't know for sure what these used stock........but is this actually a roll pin and not a broke off bolt? I'm sure somebody else can verify.
  3. ChrisPerry
    ChrisPerry Dreaming of links Premium Member GMOTM Winner
    Jan 22, 2009
    1,181
    36
    Ventura Ca
    My friend broke that one. He used up 3 reversed drill bits and a torch. It destroyed the carrier but he was replacing it anyway. The trick is to use a slow drill and a lot of lube. Try not to work harden that pin any more than you must. The reverse drill may spin the pin out if you are luckier the we were.
  4. diesel4me
    Jul 24, 2003
    15,723
    134
    Massachussetts
    Those lock bolts snap off quite often on GM diffs..a real suck pill to remove in most cases,if your lucky,you can drill it and as stated it might spin out using a left hand drill,or an E-Z out,but beware of breaking the easy-out off or you'll regret it..
    I have had to resort to using a large punch on the spider gear pin and a 5 lb.hammer,to drive the spider shaft inwards and snap off the broken lock bolt (hit the shaft with the lock screw facing you ,if you dont it can take a chunk out of the doff case if you drive it "outwards")...then you can spin the diff case 180 degrees and tap the spider shaft out,and then proceed with removing the busted lock screw--often they aren't "tight" and can be weaseled out by using a small screwdriver or punch to spin it out,sometimes welding a blob of mig wire will give you enough of a stub to grab it with and turn it out..Parts stores sell new lock screws ,,
  5. 4X4HIGH
    Dec 14, 2001
    21,954
    6
    Pleasanton, CA.
    I've posted this info once before but here it is again. A friend of mine invented and patented this tool and it works VERY WELL. They are still available as the person that i posted this info for bought one recently.
    http://www.fabbriassociates.com/
  6. vince a
    vince a Newbie
    Apr 5, 2010
    3
    downey,ca
    hey bud i got a question i have a 1985 k5 blazer with gm 10 bolt i was planning to up my gears to 4.56 or 4.88 (35 inch tires) but i dont want my diff to be weak. should i up my diff or just go with the gears and my 10 bolt
  7. 1BEATK5
    1BEATK5 1/2 ton status Premium Member
    Dec 15, 2005
    2,713
    8
    beaverton orygun
    I have that tool, and have used it many times at work. it has worked every time. no problems.
  8. gone huntin
    gone huntin 1/2 ton status
    Oct 25, 2004
    1,664
    Southaven, MS
    Welcome to the site, but don't hijack someone else's thread, but to answer your question, bigger tires= bigger axle. Put a 14 bolt under it.
  9. vince a
    vince a Newbie
    Apr 5, 2010
    3
    downey,ca
    My bad new to this still trying to figure it out BUT THANKS FOR THE TIP
