8274 mount/ bumpers.
Discussion in 'The Garage' started by bigjbear, Aug 18, 2005.
  1. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Guys running 8274s. I want to build a new bumper because mine is too heavy, sits too low, and sticks out too far. Right now my fairlead is between the frame rails. I'd like to get the winch above the frame and closer to, or even into, the grille. So, if you don't mind post some pics anr/drawings. TIA.
  2. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Here is what I have now, 4" lift & 35s:
  3. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Here are a couple of pics of the bumper DP_90K5 built for me. The winch is still positioned down between the rails and very close to but out in front of the grille. I haven't installed the bumper yet so I don't have any pics of it on my K5.
  4. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    if you haven't yet, you can cut the front ends of your frame rails and re-weld the mounts.
  5. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    If it was tucked in far enough that that the bumper wasn't sticking out past the frame horns that might work. I still think it would be better on top.
  6. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    I will have a bumper from Jesse at Blazenoffroad here monday. Give me a week or two to get it mounted and I will post up. :laugh:
  7. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Here is my homemade job.
  8. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    Heres my home made job. Never got around to finishing it, adding bracing on the sides into the frame. Now both sides are bent and kinked in. :crazy:
  9. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Thanks guys!
    So far jays' is most like what I'm looking for. Did you just weld the bar to the front? But I think I will tuck it in like poohbair's, maybe.
    Poohbair, do you like the H1 rims? They look like 12B, which run flats are you using? What size tire? (that is my next mod)
    Everyone, did you bend your mountplate or weld the 90*?
  10. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    My front plate is welded, not bent. It is back to about 2" from the radiator which is all I felt comfortable with (didn't want body flex and stuff getting the radiator into the back of the winch...)
    Yes, mine are 12B rims w/ the rubber runflats and the tires are 38x15.50R16.5 TSL Radials. Work great... I just sold those tires and wheels because I am going to sell my D60/D70 and don't need them anymore.
  11. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
  12. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    I ended up putting in another corssmember more towards the front and then capping the ends of the frame. Off the crossmember come two tubes up to the front bumper tube. Then you have the 1/4" plate on the bottom that is a skip plate but also adds a ton of strength to the bumper. Then you have the piece that the winch is mounted to, and its side braces. It does well for me. Has pulled me out a few times along with several other fullsizes. I love the speed of this winch. :D
  13. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
  14. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    jay, 1/4" plate attached directly to the bottom of the fram rail? Or am I missunderstanding you?
    MTMike, did you build that? Do you have any close ups?
    Once again, thank you for the input.
  15. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    bottom of the crossmember I installed, and the 2 tubes going from it to the front tube. See if these pics help out some.
  16. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    No. MNorby from on here did, and I bought them from him this summer. Then I had a buddy help me (read "do it for me") build the winch mount for it. I've got some closeups of it without the winch mount, but will have to take some for you of the winch mount later tonight.
    High res photos:
    http://mdhines.redlinebillings.com/gallery/albums/userpics/10001/P1010008~3.JPG
    http://mdhines.redlinebillings.com/gallery/albums/userpics/10001/P1010026.JPG
  17. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Thanks for the close ups guys.
  18. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    I'm still trying to get you some closeups of my winch mount, but working 16 hour days for the last 3 days has taken it's toll on my free time.
  19. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    No worries, what you posted already has helped a lot.
  20. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    Here's the winch mount.... all 1/2" plate. I just need to prep & paint it
