8274 Trouble please help ASAP
Discussion in 'The Garage' started by Elevator Man, Jan 31, 2007.
  1. Elevator Man
    Elevator Man 1/2 ton status
    Dec 23, 2005
    240
    Bigelow, Arkansas
    New Motor, new solinoid pack, new controller. I hooked everything up I just mentioned and I only have Power out no power in the relay just clicks. also it is a five pin controller, should it be a 3 pin???
  2. 53chevy
    53chevy 1/2 ton status Premium Member
    Dec 29, 2004
    369
    7
    pitcairn
    Check your grounding of the motor
  3. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
  4. Elevator Man
    Dec 23, 2005
    240
    Bigelow, Arkansas
    It has to be in the pack, I swithched the feilds and now it will run in the opossite direction. could one off the solinoids be bad and only one picking?
  5. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
    Make sure everything is tight, it would click on mine when there was something loose and not getting enough current.
  6. Elevator Man
    Dec 23, 2005
    240
    Bigelow, Arkansas
    everything is tight, I took the cover off and checked. The feild wire that hooks to the motor is not getting any voltage on it. I checked it with my meter and I think only one solinoid is picking, arn't two of them suposed to pick. does any one have a picture of a five pin pack, or a simple scamatic?
  7. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
  8. Elevator Man
    Dec 23, 2005
    240
    Bigelow, Arkansas
    That link is for a 3 pin setup Is mine is a 5 pin wouldn't it be different?
  9. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Are all 5 pins used? The troubleshooting process should be the same.
  10. Elevator Man
    Dec 23, 2005
    240
    Bigelow, Arkansas
    I'll check it out when it gets daylight!
  11. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    Two solenoids should energize in each dierction.
