'83 208 rear stock driveshaft
Discussion in 'Parts & Trucks Wanted' started by racercrazy, Jul 19, 2004.
  1. racercrazy
    racercrazy 1/2 ton status
    Dec 29, 2001
    145
    O\' Fallon, MO 63366
    \'83 208 rear stock driveshaft
    I need a slip yoke driveshaft for an 83 manual/208 10 bolt blazer. The drive shaft I'm needing uses the u-joint with the bigger caps (if that makes any sence). Please help me out.
    thanks.
  2. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Re: \'83 208 rear stock driveshaft
    Hey, I guess you scored that trail rig you wanted, eh?
    I'll keep my eye open for that driveshaft.
  3. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    got one
    30 + ride /forums/images/graemlins/deal.gif
  4. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    I have the stock drivehaft out of my 82 350/208 setup. Minus the slipyoke portion. Let me know if you need it.
    Blake
  5. racercrazy
    Dec 29, 2001
    145
    Yeah, it looks like its going to work out in my favor. But I do need to get it out of his way and put it some where else for the time being. More than likely it's going to be a winter project. Still have to do a couple of things to the 89 first. I need the drive shaft to move the 83 safely.
  6. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    the shaft i have is outta 83k5 with 700r4 and 208 pm me if you want it
    comes with the slip yoke too
    /forums/images/graemlins/waytogo.gif
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The shafts out of manual transmission rigs use the larger 1350 ujoints. Only a shaft from a manual truck will work for the joints and posibley because of length too.
    Harley
  8. racercrazy
    Dec 29, 2001
    145
    Thats what I was talking about with the bigger caps, the 1350 u-joints. I just couldn't remember what they were called right then and there. Thanks Hossbaby50.
  9. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    got one you pay shipping, it needs new u-joints so I won't charge you for the shaft
    out of a 84 blazer 465/208
  10. racercrazy
    Dec 29, 2001
    145
    TTT?
  11. crazykev4x4
    crazykev4x4 1/2 ton status
    Jun 30, 2003
    430
    Watertown,Wisconsin
    i have one from a 465/208 10 bolt rear it has the 1350 u joint in the back for the bigger yoke that the manual trans blazers had hows 30.00 plus shipping sound its a good shaft with good joints . i went to a fixed yoke so i dont need it any more
    Kevin
  12. racercrazy
    Dec 29, 2001
    145
    Sent you a pm.
