'83 3/4-ton calipers versus '75 3/4-ton Calipers - and Rotor question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by IGOR, Feb 4, 2003.
  1. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    \'83 3/4-ton calipers versus \'75 3/4-ton Calipers - and Rotor question
    What will the difference be in a 10-bolt 3/4 ton axle's caliper from an '83 pickup, versus a caliper from a '75 Dana 44 - are these banjo-bolt style brake-line mounts?
    Also - are the rotors the same for the 3/4-ton 10 bolt versus the 3/4-ton Dana 44?
    Thanks!
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Re: \'83 3/4-ton calipers versus \'75 3/4-ton Calipers - and Rotor question
    Rotors are the same...
    Calipers have different sized banjo bolts.
