83 3/4 ton ride height
Discussion in 'The Garage' started by fordslayer383, Feb 16, 2005.
    it just noticed the other day that my truck sits lower on one side in the front
    and the tire looks like the top is tilted in. is this a camber thing or will a sagged- out spring make it look like this?
    thanks
  1. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    bent tube??
    A saggy spring will lower that corner of the truck,but wont make the wheel tip inward,that is either a camber problem,or more likely a bent axle tube--if the truck has been off-roaded hard,and got airborne a few times,it might have a bent axle tube--I see some trucks with plows that had the same problem,too much weight for a 10 bolt to handle when driven by a leadfoot that doesent slow down for speed bumps and potholes--an axle truss rod helps beef the axle up and prevent bent tubes.....look your frame over closely for cracks too,its not that uncommon to see cracked frames on GM trucks too..:crazy:
