83 chevy 3/4 ton - 8 lug axles
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 83k5blzrbob, Oct 23, 2007.
  1. 83k5blzrbob
    83k5blzrbob Registered Member
    Aug 7, 2006
    40
    3
    Waterford Michigan
    I have a line on a pair of front and rear 3/4 ton axles with 4:10 gears out of a chevy truck. Would these be a direct replacement for the current 1/2 ton axles that came in my 83 blazer?
    My blazer originally had a 350 / 700R4 / NP208 / and corporate 10 bolts front and rear with 3:42's. I am looking to run 35" tires once the blazer is completed.
    What, if anything, would I need to change to run the 3/4 ton axles?
    Last question - any cons to running the heavier axles?
    Thanks for the advice,
  2. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    you'll need a conversion rear u-joint and 8 lug wheels. some changes may be necessary for the e-brake.
  3. 3/4 Ton Blazer
    3/4 Ton Blazer 1/2 ton status
    Sep 23, 2007
    177
    PNW
    The e-brake cable change is pre and post '84 I believe, so if your truck is later than 84, then you will probably have to get new brake cables.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,161
    Sacramento, CA
    I think it was 81 and up, the dash changed in 84:D
  5. 3/4 Ton Blazer
    Sep 23, 2007
    177
    PNW
    I was just researching this for my axle swap, and all of the parts places that I looked at online had the same part number up to '83, and the '84-'87(-'91) had the same part number.
  6. 83k5blzrbob
    Aug 7, 2006
    40
    3
    Waterford Michigan
    All, thanks for the information. I was planning on replacing the current e-brake cables since they are frayed and was looking to update to the 84 and up style. I think they run along side the rocker on the driver side instead of being separated and supported by hangers form the trans on back.
    I'm doing a frame off restoration and the truck will most likely only see light wheeling, does it make sense to change over to 3/4 ton running gear? It's the 4:10's, and the price, that's pushing me in the direction of the axles. Will I be limited on wheel selection?
    Yzeater, what exactly is a conversion joint?
  7. YZEATER
    Jan 21, 2005
    2,358
    TARENTUM, PA
    it allows 2 different sized yokes to be mated together.
  8. imiceman44
    Aug 5, 2002
    15,161
    Sacramento, CA
    going 3/4 ton to get the 4.10 ratio will be cheaper for you, and it's better stronger.
    Wheel selection shouln't be a problem, if you want to go 15" and you want deep backspacing you might need to grind slightly on the calipers otherwise everything should work on the 3/4 tons.
    As for the conversion U joint, you could bypass that and get a 1350 yoke for your Tcase and run a 1350 driveshaft, might be more expensive than the conversion U joint but you can get a better Ujoint and it will be a stock U joint that you can get at any store in cse of a failiure.
  9. 83k5blzrbob
    Aug 7, 2006
    40
    3
    Waterford Michigan
    Alright. looks like 3/4 tons it is. I'm planning to go look at the axles this weekend and if the're good, I will have some additional work ahead of me. Also I may have some 10 bolts for sale if it works out.
    Thanks for the information, I hope I can return the favor sometime.
