83 diesel conv. POS tranny and engine troubles
Discussion in 'The Garage' started by tweaker, Jan 11, 2005.
  1. tweaker
    tweaker 1/2 ton status
    Mar 21, 2004
    263
    Modesto, CA USof Freakin A
    i bought this K5 a couple years ago and it ran like a dog. since i've upgraded to a sb406, edlebrock intake, holley carb, headmen headers, glasspacks, and oh yeah no smog equipment.
    here's where the problem is. the tranny shifts wierd(think it's due to the fact it was a diesel first). engine is set @ 8degrees BTDC(just sounded good from way back in auto shop(but it back fires when warmed up and hesitates while reving).
    any help welcome on either the tranny thoughts or engine troubles.
    thanks
    Dillon Carson
  2. tweaker
    Mar 21, 2004
    263
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    auto trans ? or ?
    what model ?
    you know diesel torque converters are less stall speed than gas right ?
    if 700r4 then its most likely incorrect TV cable adjustment, 700r4 are very picky about cable position and if its far enough off it will hurt the tranny bad
    good luck
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    If it's a TH400 there are at least two things different about the OE diesel versions. The converter as mentioned, and the govenor. Find a gasser TH400 govenor for it. If the 406 has a lot of low speed torque the converter may work.
  5. tweaker
    Mar 21, 2004
    263
    it's the 700r4, how do i adjust the tv cable and know it worked?
  6. tweaker
    Mar 21, 2004
    263
