'83 Jimmy 10b Broken Carrier
Discussion in 'Pacific Region' started by tackettb, Jul 24, 2002.
  1. tackettb
    tackettb Registered Member
    Jul 18, 2002
    49
    Tacoma, Wa
    \'83 Jimmy 10b Broken Carrier
    First off I'd like to get it back on the road, then I'd like to upgrade to atleast a 12 bolt with 3.73 or 14b 3.73-4.11 and an eight lug front to match?
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: \'83 Jimmy 10b Broken Carrier
    first off a 12bolt is only just a tiny bit stronger then a 10bolt so it would not be worth the change so i would say go with a 14ff
  3. tackettb
    Jul 18, 2002
    49
    Tacoma, Wa
    Well Price matters, if I come across something that gets me back on the road cheap, then that may just work for the time being.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    this is very true /forums/images/icons/grin.gif what area are you in? are you close t portland i might be able to find you a cheep 14ff /forums/images/icons/grin.gif
  5. tackettb
    Jul 18, 2002
    49
    Tacoma, Wa
    yeah close enough, Tacoma.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    ill do some looking around and see if i can find one /forums/images/icons/smile.gif
  7. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    I have a 14bolt w/ 3.73's that needs new spider gears ($25 parts) or a detroit locker will fix it. I need some cash to rebuild my rear axle so would sell it for $100 and throw in 4 - 8 lug rims with some useable tires. Then you can drive your truck till you find 8 lug conversion parts for the front.
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have a set of spyder gears for it that i took out of my 14ff when i put the detroit in id sell for $25 /forums/images/icons/smile.gif
  9. tackettb
    Jul 18, 2002
    49
    Tacoma, Wa
    Well guys the more I look into this rearend problem , I'm thinking I should go with the 4.11 or 4.10 gears to get my rig back to a more stock ratio with 35" tires. Bear with my though , I'm kinda learnin' as I go.
  10. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    whith 35's 4:11's would be the way to go /forums/images/icons/grin.gif
  11. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    auto or manual??
    you'd want 4.10's with an auto( or 456 if you don't care for mileage) and 4.56's with a manual or an overdrive tranny.
  12. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    actually if you have a th350 or th400 or the sm465 then go with 4:11's with a 700r4 or the nv4500 then go with 4:56's for the rpms to be good on the freeway /forums/images/icons/smile.gif
  13. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Manuals require lower gears since they don't have the multiplying factor of the torque converter.
  14. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes they do but to keep the rpms down thats the setup i would recomend /forums/images/icons/grin.gif
  15. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    and who would want to keep rpm's down???? /forums/images/icons/smirk.gif /forums/images/icons/grin.gif /forums/images/icons/wink.gif /forums/images/icons/laugh.gif
  16. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    um i would like my rpms down when on the freeway /forums/images/icons/grin.gif i dont want to spin a bearing from having to high of rpms for to long
  17. tackettb
    Jul 18, 2002
    49
    Tacoma, Wa
    Hey guys I found some axels (dana 44 eight lug and corp 14b, 4.11's), for $500/set . Sound like a fair price?
  18. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I'd offer $400 cash. $500 seams steep. but then again I paid $500 for a running burb with my axles and engine /forums/images/icons/wink.gif
