83 Jimmy electrical prob
Discussion in 'The Garage' started by Strahan, Feb 11, 2004.
  1. Strahan
    Strahan 1/2 ton status
    Dec 4, 2001
    251
    Yoe, PA
    Howdy. I've been talking about my problem in the other forum (http://coloradok5.com/forums/showfl...5237/page/0/view/collapsed/sb/5/o/all/fpart/1) figured I'd crosspost just in case someone that reads here has input.
    Last weekend my 83 Jimmy K5 headlights got real dim driving home. Checked the dash volt meter, it was in the red down by 8 volts. Figured bad alternator. Next day bought an alternator and installed it. Also replaced battery with a new one. Still had the prob. Went back to store I got it from, it tested bad. They threw a new one on and tested it, it passed. Volt meter shown high 12 volts idle. Drove it around, seemed stable. Let it sit overnight, it still started the next day and looked good. Figured all is well. Girlfriend came home tonite with the truck and said it's back in the red. Went out and it was just above 8 volts again. Shut off the headlights, it went back up to low 12s.
    Any idea what I should try now? It has a new alternator and battery. Thanks.
  2. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    I'd be checking the grounding wires for the headlights. Make sure all the contacts are tight and clean.
