83 Jimmy tailgate help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by seanp, Sep 4, 2003.
  1. seanp
    seanp Registered Member
    Sep 3, 2003
    68
    S.E. KS
    I just bought a 83 Jimmy and the tailgate won't open. There also is a rattling sound that seems to come from the tailgate. The rear window rolls up and down fine. But how am i supposed to find out what the rattling sound is if i can't get the tailgate down? Is there some sort of trick or is mine broken?
  2. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Take the cover off the inside of the gate. Find the two thin long rods going to each side and pull them inwards. The gate should unlatch.
    Once it's down you can get a better look at the latching/handle mechanism and see what's up.
    rene
  3. seanp
    Sep 3, 2003
    68
    S.E. KS
    I finally got the tailgate open. I also adjusted the striker plates and that snugged up the tailgate but the rattling is still there. When i took off the access plate there were old dried up pieces of foam laying in there. I think the foam was keeping things from touching and rattling but their worthless now. Do you think that would help if i replaced those? Everything else looks fine inside there.
  4. dyeager535
    26,980
    Foam is what "seals" the access panel to the gate to keep it quieter/less windy inside.
    Leave the panel off and see if the noise goes away. Might be something else going on.
  5. seanp
    Sep 3, 2003
    68
    S.E. KS
    I see what your talking about but that foam is still stuck to the access panel. Inside the gate was 3 foot long pieces of dried up foam. But maybe somebody added those thinking it would fix the rattling.
  6. dyeager535
    26,980
    Only foam I'm aware of is for the access panel.
    You are probably right, added to try and fix the noise, instead of actually searching for the problem. /forums/images/graemlins/smile.gif
  7. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    There are two vertical guides for the glass on each side of the gate inside. I'd look there for possible rattling. Either one of the tabs that allows it to be bolted in is broken and the guide is rattling or ???. The guides should also have felt in them...if it's worn to bare steel the window sash will rattle around in the guides whether it's up or down.
    You just have to spend the time to get familiar with the guts in there and see what moves and how. Then see if anything looks amiss.
    Rene
