83' K/5 with Heavy squeals
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77blazin, Aug 27, 2002.
  1. 77blazin
    77blazin 1 of a kine K5
    Mar 31, 2000
    394
    Honolulu Hawaii
    83\' K/5 with Heavy squeals
    Hello Everyone!
    Again I have another question, My Uncle has a 83 K/5 with 31x10.5x15s, There is a heavy squealing sound on the passenger front tire, I mean the damn thing is loud.
    My Uncle ignors it, but it does bother me, the brake pads are new and I know it doesn't sound like that (Brake Sensor), its coming from behind it and it only squeals when the blazer is in motion.
    Anybody wants to give me ideas if this is a critical situation or not.
    If it wasn't for my Uncle, I wouldn't have gotten a blazer in the first place.
    Please let me know, I would appreciate it fully.
    Sincerely
    Michael W. /forums/images/icons/smirk.gif
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Re: 83\' K/5 with Heavy squeals
    Does he have manual hubs on it? In other words, is the axle shaft turning or not?
  3. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Are you sure that maybe your power steering pump isn't low on fluid? It will make a hellacious squeal when it's low.
    John
  4. StonerK5
    StonerK5 1/2 ton status
    Feb 13, 2002
    183
    Phoenix Arizona
    Wheel bearings maybe?
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,092
    492
    Grand Rapids area
    What kind of brake pads are they? Was the rotor recently replaced? Some brakes can squeal terribly from day one.
  6. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    Could be as simple as a rock stuck against the brakes and the rotor. I had something similar to that happen to my truck.
  7. 77blazin
    Mar 31, 2000
    394
    Honolulu Hawaii
    I don't know exactly what type of brake pads were put on, all I know is that a shop mechanic redid the brakes, as for a rock stuck in there, it could be a possibility, but the bearings could be it, this is a manual hub just like my 77, but not the 78 and the only problems I got with both vehicles is major rust and frozen bolts.
    I will have it checked by another ASE certified mechanic to have a look at this heavy quealer, I hope its just a small pebble, if not, then this truck will need some heavy grease packing and bearing checks.
    Thanks guys for the imformation, you have been very fruitful.
    Michael
