'83 K5 350 no spark
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sample, Oct 25, 2002.
  1. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    \'83 K5 350 no spark
    This is the HEI. Can someone give me a rundown on the ignition system? I am not getting any spark at the plugs.
    Chris
  2. bobsurf
    bobsurf 1/2 ton status
    Jun 26, 2001
    410
    San Marcos, CA
    Re: \'83 K5 350 no spark
    See if this post helps.
  3. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    First make sure you have 12 volts at the distributor (when the ignition is on). That is the thickest wire of the ones there. If you have 12 volts then remove the coil and ignition module and take them to autozone, they can test them for you. Desides the obvious (cap, rotor, wires, rotor bushing) the only thing left is to make sure the CAM is turning. Look in the distributor hole while someone turns it over. If you don't have 12volts with the iginition on then either you have blown a fuse (is that even fused??) a grounded wire or bad ignition switch.
    Hope that helps.
