83 K5 Blazer Diesel swap to 350 Gas
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by uukrul, Jan 30, 2005.
  1. uukrul
    uukrul Registered Member
    Jan 30, 2005
    9
    Texas
    I am trying to find out if the wiring harness inside the cab under the dash is the same in the diesel blazer and the gas blazer. I need to put a gas engine wiring harness on my 350 motor, but I am not sure if it will work with the diesel wiring harness under the dash.
    Any advice?
    Thanks in advance.
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    If there's nothing majotly wrong with the diesel, keep it
  3. g_mo
    g_mo 1/2 ton status
    Dec 28, 2004
    131
    tx
    disconnect it where in goes in through the firewall. swap the under hood harness. i did it on my buddy's '82. worked fine.
  4. uukrul
    Jan 30, 2005
    9
    Texas
  5. g_mo
    g_mo 1/2 ton status
    Dec 28, 2004
    131
    tx
    Do You Want To Sell The Diesel Harness?
  6. uukrul
    Jan 30, 2005
    9
    Texas
    Sorry, but the harness was destroyed by the mechanic I had do the swap out.
    Needless to say I have someone else finishing the job.
  7. uukrul
    Jan 30, 2005
    9
    Texas
    You don't happen to know where I can find a complete wiring diagram for inside the cab and in the engine for the wiring harness for a gas engine and a diesel engine.
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    haynes manuals have diagrams
    is good place to start anyways
