`83 K5 vs `89 Sub
Discussion in 'The Garage' started by kaos, May 16, 2005.
  1. kaos
    kaos Registered Member
    Mar 19, 2003
    8
    Norway
    Hi all :)
    I have a`83 K5 with diesel. The owner before me did some strange things with it. He took out half the A/C :confused: and messed up the eletrics.
    Couple of weeks ago I found a `89 Sub that was wrecked but the wireharnes was ok so was the heater. But when I take a closer look at the wires its difrent in many ways, the plugs for the doors are not the same. On my `83 K5 i have a red box under the dash, what is that?? The Sub did not have that box so there is no plugg for it. Do I miss some boxes from the Sub maybe?? I just took the harnes with the fusebox. The Sub did not have A/C but it was also a 6.2.
  2. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    What did the wrecked burb have for a motor?
    Don't quote me on this but i doubt you'll be able to use that harness because of the fact its probably an EFI 350 or 454 rig.
  3. kaos
    Mar 19, 2003
    8
    Norway
    The Sub was a 6.2 or 6.5 diesel non A/C from 1989, my K5 is a `83 6.2 diesel with A/C.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You know the wiring harness is also different as far as the steering column goes . Starting in 1984 the wiper switch is on the column , and I think the 89 dimmer is on the column , but would need to look at my buddys 89 burb to be sure on the dimmer .
  5. kaos
    Mar 19, 2003
    8
    Norway
    Yes, I did not think bout that, but that is poss to rewire?? I remowed one large red box, one a little smaller yellow box and a even smaller black box and the diesel started and all the lights worked so it seems I dont need the boxes and for the door plugs, I took the doors from the Sub so I just use them :)
