83' SM465 and 208
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KrebsATM02, Dec 10, 2002.
  1. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    83\' SM465 and 208
    I might be buying a SM465 and NP208 to swap into my blazer. My 700R4 Raptor is dying for the second time so i'm done with them. My question is can i mate a 205 on the back of the 465?? I believe from researching that it has a 32 splined output?? Thanks - Doug
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    Re: 83\' SM465 and 208
    It's a longer output than the older 10 spline versions...I doubt there is an adaptor easily available for that. I think the later model K30's were available with a 465/205 that was 32 spline but i don't imagine they'd be easy to find.
    Rene
  3. dyeager535
    26,979
    You can buy the kit from ORD for about $200, then have the 205 case machined to take the 32 spline stuff.
    Not sure what you do about the adapter, guess you'd have to buy a later K30 465/205 one.
    Other option is to find an older 465/205 combo and either swap output shafts or just use the combo as is.
    Neither way is "easy", but the older 465/205 combo will likely be a cheaper/quicker option, as long as the 465 is still good.
  4. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Actually, they are not easy to find, but they are out there!!!! I have one in my front yard, it was mated to a th400! It has a 32 spline input and will mate straight to a 465/208 adapter! Any 6 bolt round 205 will! The bolt pattern is the same for them and the 208! They're not cheap, cause anyone on this site know how wanted they are for there strength, Doubler application, or Th400 mating ability! The 465/205 and th400/205 are the sought after matches! I've got a 465/208 sitting in the garage, but I'm probably going to go with a Ford front end and Ford TC.....
  5. edman87
    edman87 Registered Member
    Oct 26, 2002
    42
    BAton Rouge, LA
    check with doctor4x4, he had a 465-205 combo for sale, he might be able to help you out.
  6. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I sent you a PM....Welcome aboard to the site as I see you just started posting here and probably live near by.
