84' 6.2L SUB
Discussion in '1982-Present GM Diesel' started by KRUM, Apr 21, 2002.
  1. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    84\' 6.2L SUB
    like it says 84' 6.2L silverado edition suburban it has a turbo 400 behind the 6.2 and 208 t-case and it is a 3/4 ton with that said it didn't feel like it had too awful great throttle response is this normal ? i was just test driving it today so how should a normal diesel engine with 200k act and how much should i pay for this cause i got him down to 1,600 no body damage no rust power everything and front and rear air that has just been juiced!
    thanks,
    krum
  2. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    Re: 84\' 6.2L SUB
    Diesels in general don't have very good throttle responce, thats why they're not much fun in cars. Does it smoke quite a bit? If it smokes alot and has poor throttle responce it may need to be timed. If the timing is retarded it can cause worse than usual throttle responce.
  3. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Re: 84\' 6.2L SUB
    Sounds like a great deal to me!
  4. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    Re: 84\' 6.2L SUB
    I'm dreaming for such a deal...
  5. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    Re: 84\' 6.2L SUB
    no doesn't smoke much mabe just a little. i have never owned a diesel before and this is the first one i've ever driven it just didn't seem like it had much power to me but i think he said the engine has 156K on it.i'm just not sure what to expect from a diesel so why dont you guys tell me what i should expect from takeoff to it shifting. i did notice that it shifted awful fast through the gears though. any insight on how it should act would be helpful oh yeah he said it had at least one glowplug that needed replacing mabe more
    thanks,
    krum
  6. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,793
    101
    Paducah, KY
    Re: 84\' 6.2L SUB
    Sounds like a deal. The non-turbo 6.2L isn't a power house, but it makes good amounts of torque and hp down low in the rpm range, so it isn't as bad as the numbers make it sound. Will it be slower than a smiliar truck with a 350 or big block? Yes. Will either of those trucks get 15-20mpg around town? No./forums/images/icons/cool.gif
  7. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    Re: 84\' 6.2L SUB
    do you guys think this truck would pull 35-38" just crawlin around in the woods with the low end torque?
    thanks,
    krum
  8. AJMBLAZER
    May 18, 2000
    22,793
    101
    Paducah, KY
    Re: 84\' 6.2L SUB
    Shouldn't have a problem. Several of the guys on this forum are running the 6.2L and big tires. Keep the gearing good, about 4.10's for that size, and it won't be much different than it is stock with 31" tires or so.
    Put a Banks Turbo kit on it and you'll have the hp of a fuelie 350, torque of a big block, and 20-22mpg./forums/images/icons/cool.gif $1800, but worth it if you plan on keeping the truck and using it for a long time.
  9. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Re: 84\' 6.2L SUB
    $1600 is a bargain, especially for a 4x4! Go for it!
    Casey
  10. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    Re: 84\' 6.2L SUB
    I had 37s on my truck for about 5000 miles (took them off while the truck is my daily driver) and still had lots of power. In dirt or gravel it would usually spin them if I wanted. I'm running 4.10 gears, but I think a set of 4.56 would work a little better.
  11. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    Re: 84\' 6.2L SUB
    you guys wouldn't happen to know the stock gear ration of this thing would ya considering the 6.2 t400 and 208 it has factory reciever hitch for towing its the silverado edition also
    thanks,
    krum
  12. AJMBLAZER
    May 18, 2000
    22,793
    101
    Paducah, KY
    Re: 84\' 6.2L SUB
    3.73's or 4.10's most likely. 4.56's were a factory option, but very rare.
    Best bet is to go buy some gaskets and 80w90 and crack open the diffs and find out for yourself. Bet the oil needs a change anyways./forums/images/icons/smile.gif
  13. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Re: 84\' 6.2L SUB
    I would check and make sure that the 400 is factory equipment. Most 6.2s came with 700r4s because of their lower RPM range.......
    Other than that sounds like a good deal. See if you can get some maintenance records from the guy. If the injector pump and injectors haven't been done, you can probably expect to replace them within the next 50K, especially if the guy didn't change out the fuel filters regularly.
    A good way to check if the guy was good with maintenace is to pop off the aircleaner cover and see how clean the air filter is. If the filter is dirty, chances are the dude wasn't too concerned with maintenance. Ask him when he last changed the oil - he should have done it within the last 3000 miles MAX.....
    I hope this helps a little more.
  14. arveetek
    Mar 1, 2002
    722
    Re: 84\' 6.2L SUB
    Actually, the 3/4 and 1 ton trucks used the TH400 tranny. Only 1/2 ton and light duty 3/4 ton trucks had 700R4's. I've found that most 3/4 ton 2WD trucks you find on the road have 400 trannies and 4.10 gears.....terrible highway drivers.
    Krum, check the glovebox for the option codes. It should say what gear ratio it is. If it just say's "standard," then it's hard to say. Could be 3.42, 3.73, or 4.10.
    Casey
  15. Can Can
    15,552
    136
    Re: 84\' 6.2L SUB
    Thanks for the info, Casey. I can't believe that GM twinned a 6.2 with a 3-speed tranny EVER. What kind of RPMs would you be turning at 65? It can't be good for a 6.2 to turn that fast for long periods of time...........
  16. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    Re: 84\' 6.2L SUB
    the gear selector for the auto only has 1,2, and drive for the forward gears.
    thanks,
    KRUM
  17. arveetek
    Mar 1, 2002
    722
    Re: 84\' 6.2L SUB
    Actually, it's not that bad, not much worse than an SM465 or any other tranny without overdrive. The RPM's really don't hurt the motor any, it can take it. It just sounds like it's going to come apart, but it really isn't.
    Casey
