84 Chev.Pickup 14bolt Gear Ratio?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by letsrollusaf, May 26, 2006.
  1. letsrollusaf
    letsrollusaf Registered Member
    Jun 17, 2005
    30
    Whiteman AFB, MO
    I've got the axles and they are in the truck, but don't want to pull the cover or put it on jacks and count the tire spins, but I will if need be. Does anyone know the gear ratio out of the 84 3/4 ton axles Chevy Pickup its a 14 bolt (apparently semi-floater, but don't know how to tell?) Thanks....
  2. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Okay, more than likely the gear ratio would be either 3.73 or 4.10's in the carrier. However it could be something else. Best to just pop the cover off and look for the ration on the ring gear. Now to tell if it is a semi floater or a full floater. The easiest way to tell the difference is if you look at the "hub" on the center of the drum, if there are some bolts, 6 or 8 I can't recall the exact number, then it is a full floater. If there is nothing and just looks like a little dish and is flat with the WMS then it is a semi floater.
  3. stkcode
    stkcode Registered Member
    Nov 30, 2005
    86
    Apple Valley, CA
    Without dropping the cover...the tire spins is the only way I'm aware of. Unless you still happen to have the factory sticker on the inside of your glovebox door. Usually, big blocks had ff, that I'm aware of. Most sf that I've seen have a different cover than the ff....it's more round, where as the ff is more square at the flange. Like James said...it's more than likely 3.73 or 4.10...fairly common ratios.
  4. letsrollusaf
    Jun 17, 2005
    30
    Whiteman AFB, MO
    Well they're transplanted out of the 84 into my 89 blazer, but I think I will revert to the tire spin method, can't be too hard, kinda exciteing me though because one guy told me it was a semifloat and when i was building installing all the hardware and what not on the drums i saw bolts at the back of the backplate, so who knows..
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    If you have never changed the gear oil and inspected the gears, now is a pretty good time.
  6. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    agreed. dont be lazy.
  7. letsrollusaf
    Jun 17, 2005
    30
    Whiteman AFB, MO
    agreed, you are no help...what was the point of your post?
  8. FightinTXag
    FightinTXag 1/2 ton status
    Apr 11, 2006
    140
    Fort Worth, TX
    I think the point was to second the opinion that you should pull the cover if you want to positively identify your ratio. Plus, if you've never done it you should probably be performing some PM in there anyhow. There's a lot of helpful people here. Take a picture of the hubs and the diff with the cover off. They'll let you know what you've got in the way of sf/ff or open/govlock/aftermarket posi/locker.
    But you should probably try to not be snippy when folks are offering suggestions. You were the one asking for advice afterall.
  9. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    and yours?
    im just tryin to reaffirm the point that i dont see a point in not pulling the cover on an old axle.
    who knows he may find 4.56's and a bunch of pond water in there:confused:
