84 column in 87 K5...any issues?
Discussion in 'The Garage' started by BigOrange90Jimmy, Jun 7, 2003.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    I have a chance to buy a manual steering column with tilt from an 84 K10. Will this column be ok for use in my 87 K5. I know it'll go in there and everything, but I'm more or less worried about the electronics. My K5 has cruise control because it was an automatic before. What kind of issues will I come across?
  2. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    If they both have delay or non-delay wipers, it should be the same for the most part. The manual column won't have neutral safety switch though - this should be wired through your clutch switch instead.
    The cruise stick will swap over... the hard part is fishing the wire in there.
    Come to think of it... you can swap the wiper switch into the manual column if necessary.
  4. dyeager535
    26,976
    Gotta swap the upper section if you are dealing with dimmers on the floor.
    Swaping parts over (to make one good column out of two) isn't necessarily tough, just time consuming.
