84 diesel crew cab $300.00
Discussion in 'The Garage' started by edlavarreda, Jan 17, 2004.
  1. edlavarreda
    edlavarreda Registered Member
    Nov 26, 2002
    56
    solid condition picked it up the other day how hard would it be to to put a 350 in it do not know about diesel always heard horror stories about them would love to make it a short bed may be 2003 bed and front clip and blend in the cab with the new parts any ideas input is welcome thanks gurus
  2. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    uhhh thats quit a lot of work ur talking about there unless ur a really good body man lol..
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Input:
    Learn to form a sentence and use punctuation. A clear understanding of the English language goes a long way here.
    These trucks are very easy to work on and modify. I'd leave the Diesel if it runs alright. Otherwise, the gas engine will bolt right in. It will obviously require some fuel system modification.
  4. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    dont forget a different tranny if youre going diesel to gas
    Later
  5. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    You do not need a different tranny. I didnt even swap the converter on my T400 when I put the 454 in.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah tranny are same i dont know why ppl think they are different, but the converter are different stall ratings form gas to diesel i have been told
    and as far as putting 03 clip and bed on the truck, good luck
    you better be one of the best custom fabircators in the world to be able to pull off such a bunch of major modifications, sounds like you need to go just buy a 2003, dont ruin a good old work truck trying to do crazy things to it that are in your imagination, you wil just end up wasting money and ruining an innocent old truck
    but good luck anyways
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The trannies also have different governors. Diesel trannies upshift at wide-open-throttle before most gas engines have even hit their torque peak. /forums/images/graemlins/wink.gif
  8. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    this is true. My cousin put a 350 in place of his diesle and at WOT that thing did the 1-2 shift at like 3400 RPM, /forums/images/graemlins/deal.gif or somthin crazy like that.
  9. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    as placed in posts after mine the trannies are different...or aspects of them anyway...you dont want a gas motor shifting at points that a diesel shifts because you wont be able to take advantage of the full power band...
    Later
  10. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    So can't he just get the governor changed?
  11. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    yeah, and possibly the torque converter...im not too automatic tranny savvy...i just knew that there were differences and it is a good idea to just change the whole thing
    Later
  12. BlackDog714
    Jun 8, 2002
    260
    Indiana
    On my T400 all I did was replace the vacuum modulator on the side of the trans with a $10 B&M mod... Shifted just fine after that and it allows the motor to go to redline.
  13. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    Interesting. My only experience has been with t400 and 208s out of military trucks...ive had two of them that came from behind diesels swapped into other trucks and didnt run correctly...so we just swapped them out totally
    Later
  14. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    If it runs all right keep the diesel. Most of the horror stories you probably heard involve either the Olds 350 diesel or the common misconception that the 6.2 and the Olds 350 diesel are related. They are not related at all, and the 6.2 is a decent motor if maintained well (like anything else)
    I kinda like pulling down 16-18 mpg with a 6000 lb truck on 40's.../forums/images/graemlins/thumb.gif and it's got plenty of power for my needs.
    rene
  15. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I would say stay with the diesel. Deisel's have plenty of torque that big trucks need. Plus, not everyone has one. /forums/images/graemlins/thumb.gif
  16. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    This has already been said but...
    If the diesel runs good, keep it. Nothing wrong with a good 6.2 as long as you don't want a hot rod. Good reliable motor that gets good mileage. A turbo and/or other mods will pep it right up if you want. 6.5 TD is another upgrade.
    I've personally swapped out a dead 6.2 from my truggy and reused the Th400 trans and converter for a while with the transplanted 350 TBI. Total bolt in operation except for the fuel lines and tank pump which need to be addressed. The motor mounts are the same and even the exhaust will often fit depending on the exhaust manifolds. Just get the complet harness, throttle cable, accessories and brackets, etc. with the new gasser...
  17. edlavarreda
    Nov 26, 2002
    56
    I had a friend go over it today and he says the engine is barbely broken in with 160.000. IM planing in using 44 boggers and a 700r4. what gearing do you recomend?
  18. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    5.13's
    Rene
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    5.13's
    Rene
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Normally I'd be with ya on this one.
    44 boggers and 700R4? 5.86s. Questions? PM K5DRAGER about his. /forums/images/graemlins/thumb.gif
  20. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    It's a diesel...I run 40's with 4.56's (with my 6.2) and it's just about right. Besides, anything lower than 5.13's means D70 rear instead of the more common and easier to build 14 bolt.
    Lastly, when the 700R4 blows up and he get's serious and drops in a TH400 he'll still be able to drive it at a reasonable speed with 5.13's and no overdrive.
    Rene
