84 Full Size Blazer questions on the clutch
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ben Malinski, Feb 25, 2002.
  1. Ben Malinski
    Ben Malinski Guest
    Thanks for reading my letter and hopefully you can help me out. We installed a centerforce clutch a few years back and due to the lack of driving, I have put on a little less than 15K since it was installed. New bearing, plate, fork, clutch, etc.
    I'm not up on how to adjust the clutch so it's been trial and error. I've got a mechanical clutch setup.
    My question: when engaging the clutch, holding it in at a stop light or stop sign, I can "feel" something spinning through the clutch pedal. If I let up on the clutch just an inch, the spinning stops. What gives? Do I need to readjust the clutch? If so, how much? Right now when I step on the pedal, I have about 3 inches of play before it engages and the I hit the floorboard. When I release the pedal, the truck does not start to move until the pedal gets halfway up. Any advice is appreciated. Thanks!
    I don't know the secret to success but the key to failure is trying to please everyone!
  2. Big_B_Murphy
    Big_B_Murphy 1/2 ton status
    Dec 28, 2001
    New Stanton, PA
    If you are feeling excessive vibrations when you have the cluth pedal depressed, your throwout bearing may need to be replaced. My rule of thumb for adjusting manual clutch linkage is make sure the clutch doesn't slip when the pedal is released. Also make sure that it is fully engaged when the clutch is fully depressed. Unless there is excessive wear on the pivot bar or clutch rods, this can be accomplished.
    due to the fact that the mechanical linkage does wear, there is no more specific description like "make sure x number of threads are visible".
    Mechanical linkage is not a smooth or maintenance free like hydraulic linkage. It does need to be periodically adjusted.
    <font color=red> It is just as much fun to build it as it is to bash it</font color=red>
