84' K10 blazer?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBurban350, Jun 3, 2003.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    84\' K10 blazer?
    Were Blazers in 84' called K10 Blazers?
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    Re: 84\' K10 blazer?
    up until 87 i believe when they switched them to v10.
  3. michiganjim
    michiganjim Registered Member
    May 16, 2003
    7
    I believe the k10 referred to the luxury edition of the Blazer. I have an 84 k5.
    /forums/images/graemlins/k5.gif
  4. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    I've talked with several other people who had 84's that all said k10 on the title and k5 on the fenders. Both of my 84's that I've had were that way. Both were silverados with 305's.
  5. TK5
    TK5 1/2 ton status
    May 29, 2002
    319
    Fairview , Tennessee
    Mine also says K-10 on the Title and K-5 on the sides. Go figure???
  6. BRN78BLAZER
    BRN78BLAZER 1/2 ton status
    Feb 5, 2003
    133
    Stoney Creek Ontario, Canada
    My 78 2wd says C10 on the title and k5 on the side. If it did say k10 on the side I would assume the badges came from a pickup, possibly from a fender swap.
  7. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    K5 is the "brand" for the Blazer- it has no significance other than as a model name. Using GM's code it's a K10 because it's:
    4x4- K
    1/2 ton suspension- 10
    On the same note, a 2WD Blazer is a C10 because:
    C- 2WD
    10 - 1/2 ton suspension
    Your registration should read K10 because that's the configuration of your rig. If it's a 2WD Blazer it should read C10.
  8. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Yeah, what Paul said... /forums/images/graemlins/thumb.gif /forums/images/graemlins/deal.gif
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    K5 badges on them all no matter if 2wd or 4x4
