84' K5 305 stock carb CFM rating?
Discussion in 'The Garage' started by BigBurban350, Jun 9, 2003.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    84\' K5 305 stock carb CFM rating?
    What does the stock 305 carb flow for an 84'?
  2. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Re: 84\' K5 305 stock carb CFM rating?
    Is it a 4 bbl Quadrajet?
    If it is, then it's rated around 750 cfm.
  3. dyeager535
    26,979
    305 carbs I've seen from '82 and '83 are the 795 (800) CFM units.
    Dunno why GM went larger on the 305's, when emissions were more strict /forums/images/graemlins/confused.gif
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    750 CFM on a Quadrajet. The larger one's, 800 CFM were on big Buick's, and Oldsmobile's.
  5. BigBurban350
    Jun 9, 2002
    711
    Michigan
    Wow, that seems a lot for stock.
  6. dyeager535
    26,979
    As I said before, thats not true. I could probably go out to my shed and pull the carb number to prove it beyond a shadow of a doubt, but I already know. Thats one of the reasons I bought it.
    Even 307 Olds motors in the 80's had the 795CFM units.
