84 K5 driveshaft problems?
Discussion in 'The Garage' started by blazerboy1985, Mar 3, 2007.
  1. blazerboy1985
    blazerboy1985 Newbie
    Mar 3, 2007
    Oklahoma
    I just recently put a 4" Rough Country lift w/ front springs and rear blocks. I put 35s on it and sat it down off the jack and realized my rear driveshaft wouldn't spline up to the trans case. The transfer case was lowered and it still won't work. The driveshaft is 29 1/2" long from the center of the front u-joint and the center of the rear u-joint. I still need about an 1 1/2" jst to spline up. Any info would be greatly appreciated.
  2. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    That's strange; most people with 4" lift kits are okay with their factory driveshaft lengths. But obviously in your case, it sounds like you need to lengthen your driveshaft. Any way of getting some pics of it?
  3. Pvt. Maggot
    Pvt. Maggot 1/2 ton status
    Sep 27, 2005
    559
    Brownsville PA
    Did you pull the driveshaft out when you put the lift on? mine was fine, I left the driveshaf in and just pulled it out some and bolted it right back up.
  4. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    I just finished a 4 inch rough country lift today. I am a little short but spline up fine-I do have a little vibration though. There were a pair of wedges with the springs that angle the pinion up to cut down the driveshaft angle. Did you put them in?
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Is yours a "all spring" lift ? Most kits with blocks have a taper on the block itself . And they go in in the orientation on the instructions .
  6. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    All spring lift. Came with wedges that were mounted to the botom of the spring pack that are removeable/interchangeable. I just was wondering if he had an all spring kit with the wedges or just blocks.
  7. blazerboy1985
    Mar 3, 2007
    Oklahoma
    My kit was a front spring and rear block kit. I put the shaft back in yesterday and it worked, for about a minute. As soon as I got it out on the road I felt a little vibration and the first bump I hit caused the shaft to come unsplined. I know the driveshaft is the right one, but I don't think the yoke is the right. How long should the yoke be? I noticed a picture of another Blazer's yoke and it was definitely longer than mine. Is it possible to use a driveshaft out of shortwide bed pickup or is it the same length?
  8. Vetteman61
    Vetteman61 Registered Member
    Jan 11, 2007
    93
    Kentucky
    Driveshaft length
    I JUST got through resolving the same problem. I put 4" lift on, springs up front, blocks in rear. The guy I bought it from had no problems with length or pinion angle. No one else ever did ever, but I did. I had a huge problem. My driveshaft stuck out far too much, but did spline up, but when I went to stop there was a huge vibration and horrible noise. It felt and sounded just like a brake problem, but it turned out to be a driveline problem. The driveshaft wasn't in far enough and caused a binding under weight transfer during breaking. I did a transfer case drop, and it helped, but didn't fix it completely. I had to have my blocks machined to change the angle and everything is perfect now. I have about 1/4 to 1/2 of driveshaft further out than before.
    We believe the reasons for this is that my rear springs had sagged severely, causing sag and pinion angle problems, thus length problems. The measurements that worked for me were 1" transfer case drop and then the measurements for my blocks were 3 inches in the front, 4 in the rear. I experimented with temporary wooden blocks to get the right angle.
