'84 K5 Fuel Pump ..... In Tank (electric) or in Block (mechanical)?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stoopalini, Jan 22, 2001.
  1. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    \'84 K5 Fuel Pump ..... In Tank (electric) or in Block (mechanical)?
    My K5 is an '84 and it has an electric fuel pump. I just dropped the Gas Tank and there is a fuel pump in there.
    I then called around looking to see how much a high flow pump would be, and I'm told that it should have a mechanical pump, not electric.
    Does this mean that the previous owner swapped tanks? My Engine is a replacement 350, so maybe they swapped tanks to go with the new engine?
    Thanks,
    Thomas
    -- '84 K5 Blazer --
    <A target="_blank" HREF=http://Stoopalini.coloradok5.com>http://Stoopalini.coloradok5.com</A>
  2. KENBARBOUR
    KENBARBOUR Registered Member
    Jan 14, 2001
    54
    Re: \'84 K5 Fuel Pump ..... In Tank (electric) or in Block (mechanical)?
    The only trucks I have ever seen with the fuel pump in the tank are fuel injected ones and diesels(fuel injected, also).I dont think k5s were injected until 87. Are you sure there is a pump in there and not just the fuel level gauge? The sending unit on mine is grounded and has an orange wire for the fuel gauge. Either way i dont think you would need a high volume pump unless you had a lot of engine work.
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Yeah, previous owner probably put it in with that new 350 cause on my 84 I have a mechanical pump.
    Murphy's Law :
    "When you don't know what your doing, do it neatly."
  4. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Well, I replaced an in-the-tank fuel pump on my previos vehicle (88 Fullsize Jimmy 4x4). When I dropped the tank in this K5, it looked just like the Jimmy did .......... except there are only 2 wires going to it, like Hellraisers's.
    I guess it has the mechanical and the wires must be for the sending unit ..... DOH! my fault [​IMG]
    -- '84 K5 Blazer --
  5. KENBARBOUR
    Jan 14, 2001
    54
    Glad i could i help. You never know until you ask. By the way, hows your shackle flip going? Did you get the rivets out yet. I did mine 2 weeks ago. It was the best mod I ever did to my blazer. I used a grinder and i had to elongate the two holes on the very bottom with a drill. That might just be because of my frame being tweaked. Did your kit come with enough washers for both the bolt and nut sides? The instructions said it should. Mine didn't so i put the washer on the inside. I figured i could always add more washers on the nut side (outside) later rather than dropping the tank again.
  6. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    It's coming along pretty good. No big stumblers so far.
    I Haven't removed the rivits yet and I'll probably end up doing it on Thursday.
    You can check out some pics at <A target="_blank" HREF=http://stoopalini.coloradok5.com>My Website</A>.
    Stephen over at ORD shipped my stuff today. So with any luck, it should be here on Thursday --- just in time for our run to 'The Slab" this weekend [​IMG]
    I'm gonna try and document this whole thing so others can benifit. What do ya think so far?
    Thomas.
    -- '84 K5 Blazer --
