84 K5 w/Quadrajet - Low idle in gear?
Discussion in 'The Garage' started by Can Can, Oct 15, 2006.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I have an odd thing happening with the K5. The truck starts, runs, and drives like a champ. The only issue I'm having right now is that my idle is too low in gear while stopped at a light. Out of gear, the idle is fine.
    If I take her out of gear while stopped, it bumps up to where it should be. The second I put her back into gear, it drops too low again. When I go to accelerate when the light turns green, there is no bogging or hesitation....:dunno:
    My choke is adjusted properly. The timing was bang on last I checked. I'm not running rich or lean, either. And as far as I can tell, I have no vacuum leaks anywhere. Of course, a vacuum leak should cause idling issues in park, too.
    Does anyone have any ideas?:confused:
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    vac. modulator on the trans? you could always try bumping the idle speed at the carb like 1/8 of a turn...
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Does it feel like it's trying to 'drive' more than it used to when you're stationary in gear?
    If the engines not bogging at all and running on all 8 at idle(?) it would seem to be excessive parasitic drag. 'tis a strange one though!
  4. Can Can
    15,552
    136
    I've got a 700r4, brother.
  5. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    How many miles on the engine? Sounds like a timing issue to me and or worn cam. Also when was the last time You adjusted You valve train?
  6. Can Can
    15,552
    136
    The motor has 180K miles on it.
    Like I said, Corey, the timing was bang on last ime I checked it. I *imagine* that the cam could be worn a wee bit, but you'd think that would also affect overall driveability. As far as adjusting the valves, it's never been done.
    Does anyone else have any input? It just seem odd to me that the idle issue is only apparent while in gear......:dunno:
  7. Corey 78K5
    13,055
    Humboldt County, CA
    I just thought of another problem You should check. I had fuel problems with Mine about 10 years ago. Ended up being rotted fuel line's on top of the fuel tank. They were the original factory lines and in bad shape.
  8. ryoken
    Jun 13, 2003
    29,624
    1,379
    Jersey Shore
    Run a couple cans of Seafoam thru that sucka... Throw em in the tank... Check for vacuum leaks as noted too...
