84 K5 with computer??
Discussion in 'The Garage' started by tcoker79, Aug 23, 2006.
  1. tcoker79
    tcoker79 Registered Member
    Feb 16, 2006
    38
    Creedmoor, NC, USA
    I'm sure this is a silly question, but why does my 84 K5 have a computer under the dash? Any feedback would be greatly appreciated.
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    485
    Grand Rapids area
    If the truck is a California model, then it could be the ECM for the computer controlled carb. Otherwise, it is the ESC module - an add-on for the HEI distributor that retards timing when knock is detected.
    I also feel obliged to mention that the K5 in your avatar is not an 84. :-)
  3. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    He knows it's not an '84, look at his username. ;)
    There are a couple of boxes under there that you could be seeing. For example it could also be the cruise control box.
    Oh, and yeah like he said if it's a California truck it has more junk on it as well like mine. There is a computer to control some of the emissions.
    -Avery
  4. tcoker79
    Feb 16, 2006
    38
    Creedmoor, NC, USA
    Yea, I know the black one is a 78 that i'm having to do alot of rust repair to. So assuming it is not a california truck, the esc module should probaly be connected... I was working under the dash when I came across this "computer" that was not connected. Would that have anything to do with the carb loading up really bad?!?!
  5. tcoker79
    Feb 16, 2006
    38
    Creedmoor, NC, USA
    Close, stupid I know 79 is birth year!
  6. dyeager535
    26,975
    Need to figure out if it really is the ESC module, or as stated, the Cruise module. Typical ESC was on the passenger side above the glove box, but I've heard (but not seen) of it being on the drivers side.
    Always seen the cruise control module above the gas pedal though.
    Problematic ESC can be the culprit for driveability issues.
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    is it or was it a 305 truck? If so it would be the ESC module(looks like an ECM). It would not be a reason for the truck loading up. ESC is there to retard timing in the event of detected spark knock. However, if you have the ESC distributor with the ESC module disconnected, its going to hurt power because I beleive it defaults to the retarded setting. However in my experience(with my 84 K5 that had ESC) the truck wouldn't run without the ESC module hooked up until I put in a different distributor(mainly its the ignition module in the distributor).
  8. tcoker79
    Feb 16, 2006
    38
    Creedmoor, NC, USA
    Defiantely not CC module I actually know what that looks like..amazing i know. So what reason would someone disconnect the esc module?
  9. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    When I got my truck and took it to have it smogged it didn't pass because of too many HydroCarbons (aka too much raw fuel spitting out) and we found that the p/o unhooked the computer for unknown reasons and when we hooked it back up and re-tuned the carb it ran like a whole new animal. That could be it.
    -Avery
  10. tcoker79
    Feb 16, 2006
    38
    Creedmoor, NC, USA
    Great now I have to have someone check out the carb, I have no clue how to do that. It would be nice if that was the problem though.
    Oh by the way, yes it is a 305 in the truck.
  11. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    It is a quick job for someone who knows what they are doing. Find a reputable shop in town and it will cost you less since it's not parts just labor. Mine took less than 1hr. Even at full shop time around here that's like $75, not much to have it running correctly and have everything setup the way it's supposed to be.
    -Avery
  12. tcoker79
    Feb 16, 2006
    38
    Creedmoor, NC, USA
    Thanks guys for all your help, I'll have it checked out and see what happens. Thanks again!
