84 k5 wont start please help i am a noob
Discussion in 'The Garage' started by DomeD U, Jan 25, 2007.
  1. DomeD U
    DomeD U Registered Member
    Jan 21, 2007
    27
    wichita falls, texas
    Well i went to give her a tune up and now it won't start. So I put the old coil and cap back on and stillnothing. I am not getting any spark at the plug ( i pulled one back out and held it against the frame and I can get no spark.) The pink wire goes into the cab but I cannot tell where it goes from there nor could I find a blown fuse. Someone please help. I am new to the Blazers but I am not a noob at working under a hood. Also I ran a wire from the hot of my battery to the pink wire to see if it would fire off, and it did not. Please help, where do I look first?
  2. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    HEI or points???
  3. DomeD U
    Jan 21, 2007
    27
    i think it is HEI, it has the coil in the cap. if that helps
  4. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    its HEI and maybe its just the fuse near the ac-unit. happened to me once on the 74. its a glass fuse on the fire wall
  5. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    did you replace the rotor under the cap??
  6. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    ignition module maybe
  7. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    that was my next suggestion,
  8. DomeD U
    Jan 21, 2007
    27
    is there a way to check it, also I do have power to the pink wire.?. I must have checked it wron before.
  9. DomeD U
    Jan 21, 2007
    27
    yes
  10. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    make sure the pink wire is hooked up to the power on the coil and not the tach
  11. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    is it pluged into the "batt" on the cap??
  12. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    beat me to it again!!LOL
  13. DomeD U
    Jan 21, 2007
    27
    yes it is pluged in correctly
  14. DomeD U
    Jan 21, 2007
    27
    also when i did the tune up, once i was finished i tried to start it, it started and ran for like 2 seconds and then it died and has not started back up. I put the old cap rotor and coil back on and it still does not run. I double checked the fireing order it is correct. I am not getting any spark
  15. lak2004
    lak2004 1/2 ton status
    Aug 31, 2006
    3,809
    Durango, CO
    Did you take the whole distributor off or loosen the adjustment nut on the block at all? Maybe messed up the timing?
  16. DomeD U
    Jan 21, 2007
    27
    after it would not start i loosened off the dis nut but I have not moved it, and even if I had moved it, it would stillbe sparking just not at the right time.?.
  17. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    i think you can test the module. get a dmm and measure the voltage to the wires that would plug into the module, if there is a little voltage at the wires when you crank it, the i think the module is bad.
    i'm not 100% sure though on that procedure, sorry, memory ain't so good.
  18. DomeD U
    Jan 21, 2007
    27
    where is the module
  19. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
  20. DomeD U
    Jan 21, 2007
    27
    thanks MO i will try tomorrow. First thing in the morning, why would it quit like that?
