84 Suburban High Beams
Discussion in 'The Garage' started by codejunkie, Mar 10, 2007.
  1. codejunkie
    codejunkie Newbie
    Mar 4, 2007
    Missouri
    I've got an '84 Suburban that that high beams don't work on. It has the dual headlight setup with the switch on the column. I pull the lever and the light on the dash comes on, but the lights outside do not change (low beams just stay on). Any input would be appreciated.
    Thanks.
  2. bronc3buster842001
    bronc3buster842001 1/2 ton status
    Sep 30, 2006
    1,996
    6
    leadwood missouri
    id check the switch on the column. where u located in missouri
  3. codejunkie
    codejunkie Newbie
    Mar 4, 2007
    Missouri
    i figured it out. i just bought this and did not know that when on high beams all four lights came on. i had just assumed that they switched when going to high beams. once i figured that out and found my multimeter i found out that the bulbs were actually out. bought new ones and it looks beautiful.
    i live about an hour from st. louis down I44.
