85 305 carb same as 86 305 carb?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bone85K5, Jul 3, 2002.
  1. Bone85K5
    Bone85K5 1/2 ton status
    May 7, 2000
    436
    Columbus, Georgia
    Any ideas? A friend of mine with an 86 k5 305 needs a carb. I have one off of my 85 and we are wondering if mine will work on his 86.
  2. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    I have one from my 86. It ran OK with it.
  3. dyeager535
    26,979
    Should. Probably not the exact same (different primary rods/jets, secondary rods/hangars maybe) but as long as neither has any electrical stuff on it besides choke, you should be ok.
    Might be one or two extra or missing vacuum ports as well, but thats not a big deal either. Just compare before bolting the other on.
  4. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Do watch out for the eletrcial connections. In 85 about the only eletrical connections were the choke and the idle mixture solenoid. But, i believe that starting in 86, they added an ECM to the rig and used it for other electrics on the carb. Just look at the wiring going to the carb to see if they match. if they do, you are probably set.
  5. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    my 86 only has the choke and mixture controls. i believe that only the cali units had ecm's.
  6. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    that's cool. i know I have the M4MEC in my 85, but I knew they went to the E4MEC right around 86/87. Wasn't sure exactly when it happened, though.
