85, 4 inch lift..driveshaft to short?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sanssocs2, Jul 24, 2001.
  1. sanssocs2
    sanssocs2 Registered Member
    May 9, 2001
    16
    Mobile, Alabama
    i got my 4 inch superlift put on my 85 k5 and the driveshaft is to short. i had to lower the transfer case on inch for now. mechanic said the one year 85 the drive shaft was 2 inchs shorter.. there is 2 inchs of clean on the yoke. has anyone ran into this problem? should i get a new driveshaft or a junkjard one? or should i get it lengthened?
  2. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I put a 4" on my '84 and its ok. Fing one outta an '84!
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I have a 86. I didn't have to lenthen anything. I did go back about 6 weeks later and dropped the t-case. But I didn't really have too........Dan
    If it ain't broke.......Don't fix it....
  4. J.R.
    J.R. Guest
    i just put a 4in lift on my 85, but i also put a 14bolt FF in at the same time. on the lift the rear drive shaft looks to short but when i put it on the ground it is fine. the front was way to short, had to get a different one for that.
    BIG BLOCK MAN
    "MORE POWER"!!
  5. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    "i got my 4 inch superlift put on my 85 k5" You let another man put his hands all under your truck!! And then you paid him to do it!! LOL... just messin with you. Anyways I got a 6" on my 85 and I'm still running the stock shaft. I dropped the Tcase though. I wheel the truck often and get it flexed pretty good. So far no problems but I'm planning to get a custom shaft made when I put my 14 bolt in.
    Rod
    Alameda, CA
    85 K5 6"ProComp 35"Boggers... and it's still not BIG ENOUGH!!
  6. flcpl4fn
    flcpl4fn 1/2 ton status
    Jan 9, 2001
    194
    Florida
    I have an 8" superlift on my 85' Jimmy, and I haven't had any problems with my shaft either. I have flexed it alot and it did what it was suppose to.
    '85 Jimmy in Jax, Fl
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Did you guys with the 6-8" lifts clearance grind the CV joint in the front shaft?
    Tim
  8. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I have a 4" on an 85 and didn't have any problems. I dropped the t-case using the factory spacers to help with angles and vibration, too. But I didn't have any problems before I dropped it either.
    Brian
    Click to see <a target="_blank" href=http://tx85gmcguy.alloffroad.com> My 85 Jimmy </a>
  9. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    The front shaft was bound up and wouldn't extend enough after my 4" lift. It would have needed new splines and a new CV so I just ordered a new one. See if there is still enough spline left. I would pass on a junkyard shaft. Either get your's fixed or have a new one made. The 4" lift seems to be transition point, for some the stock shaft works, for others it wont.
    Tim, I had to clearance grind the flats on the CV of my Tom Wood shaft with my 4" lift. Like I said the stock shaft was a couple of in too short so I don't know if it would have needed to be ground.
    Jim '80 GMC & '73 Blazer
    Tread Lightly!
    <a target="_blank" href=http://www.gmck5.rockcrawler.com>www.gmck5.rockcrawler.com</a>
  10. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    The only real problem I had was that my factory Y-pipe crosses underneath my front c/v shaft. When I lowered the t-case, the front c/v shaft began to rub the Y-pipe. I had to flatten the Y some in order to clear the dropped c/v shaft.
    Brian
