85-91 np205
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dins1, Mar 31, 2002.
  1. dins1
    dins1 Registered Member
    Jun 3, 2001
    24
    I am planning on buying a np 205 from a 90 K30 to bolt behind a 4l80e in my 72 3/4 ton suburban. What type of front and rear output shafts will this transfer case have? My 72 np205 has a fixed yolk rear output. Where can i find np205 case info that would have input and output descripitions?
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I think it will have a slip yoke, but not sure
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    They will have the slip yoke UNLESS the 205 comes from a crew cab, it should have the fixed yoke. /forums/images/icons/wink.gif
  4. dins1
    Jun 3, 2001
    24
    can i change the slip yolk to a fixed yolk useing an older tranfer case out shaft
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yolk? Egg yolk? /forums/images/icons/wink.gif
    No, but you can change the YOKE out of an older into the newer, no problems. /forums/images/icons/wink.gif
