85 blazer 6 suspension lift question (newb here)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ilikeitloud, Oct 30, 2003.
  1. ilikeitloud
    ilikeitloud 1/2 ton status
    Oct 30, 2003
    134
    edina, minnesota 55424
    hey all let me start out by sayin whats up...newayz i own a 94pathfinder with a 6inch lift. but the thing is not cuttin off-roading (stuck behind the other k5s)lol thats why i turned to a K5. i found a really clean one with only 30k on the new motor and its stock. my main concern is the lift. i would like to put a 6inch suspension lift and 3inch body with some 36s. but what i was wondering is does anyone know where i can find s 6inch suspension lift for it for a reasonable price. the suspension on the blazer seem MUCH easier to work with/lift then my IFS pathfinder and i only spent 700 to lift it. im assuming that a lift for a blazer is cheaper but where??
    any helps is appreciated
    thanks
  2. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    thanks
    yeah IFS costs bank!
    at any rate, you can get 6" BDS front springs for under $100 each from www.jdsoffroad.com. In the rear, I'd do an echobit shackle flip (if they still make em!) and a ORD zero rate.
    All of that stuff won't cost you much $... but when u go 6" or more, you're going to need some kind of steering correction and to lengthen your driveshafts too. Any shaft shop should be able to lengthen ur shafts. For steering, you're going to need a raised steering arm...or drop pitman arm... or drop draglink. Sometimes for lots of lift, people use a combo of 2 of those things. The best option (not cheap, but best!) is to go with a complete crossover steering system. I got mine from www.rockstomper.com works great.
    btw, you can save urself lots of $ and head aches by going with a smaller amount of lift. I run 39.5s on my 85 that has 5" of suspension lift and 1" of body lift... all you need to do is trim to fenders and you could fit the 36s you want very easily with a 4" lift.
    lots of tech floating around ck5 with respect to lifts... i recommend you do some searches... thats the fastest way to build up a good knowledge base about this kinda thing..
    j
  3. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I have an 85' with a 6" suspension and 3" body. Go with the 9"+36's, that will look sweet and you won't have to hack up your fenders. You probably won't need shafts made, the slip yoke should be OK. I haven't had any problems with my shaft and I'm actually running 7" in the back.
  4. bigjbear
    Feb 18, 2000
    13,964
    446
    Marietta GA
    If you are going to wheel it just stick w/ the 6" lift and pass on the body lift w/ 36s. You will need to trim your fenders, espically if you disconnect the sway bar. Those 36s will be pushing the stock axles to their limit.
    From past posts Tough Country springs seem to be the most popular, followed by Skyjacker and BDS.
    Here is a good place to start shopping www.offroaddesign.com
  5. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Thats what Im planning on doing. 6" w/ 36's on 3/4 ton axles. I just have to decide on what tire width so trimmin stays to a minimum.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    6" lift would need longer shocks and brake hoses and drop down pitman arm, theres probably a good 100 or 125 bucks right there plus i dunno how much for drop down pitman arm right now
  7. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    If you are looking for a cheap place for a Tuff Country lift, try of all places, JC Whitney. I bought mine for under $300, including shipping. Tuff Country lifts are probably the most complete & have the most straight forward directions.
  8. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Don't forget that with most 6" lifts you'll also need exhaust modifications. The front driveshaft will hit the crossover pipe just in front of the trasfer case if you still have a stock exhaust system.
  9. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    if ur on a budget, you oughta lurk the FS forums here... there are always peeps unloading old steering parts when they go x-over... or springs/ubolts/blocks/shims etc when they go coils. /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
    j
