85 Chevy 1 ton
Discussion in 'Complete Vehicles' started by kvciiipenny, May 11, 2005.
  1. kvciiipenny
    kvciiipenny Newbie
    May 1, 2005
    3
    Indiana
    85 Chevy One Ton 6.2 T400 456 gears Detroit rear.
    18,000 miles. From OFF ROAD DESIGN 203-205 2nd generation doubler kit.
    Shackle flip, heavy duty front shackles, high steer, cross over steer
    Red neck steering system, triple stick shifters. 205 Shift rails ground to work independant of each other. Cromemoly Studs for high steer arms.
    Shortened wheel base by 10". Moved spring mounts forward by removing rivets and bolting mount back to frame - using 63" long rear leafs from a 88 Chevy 1/2 ton. 8" lift in front using Super Lift springs. Back springs a helper spring and 2" blocks lowered spring mounts. EXO Skeleton Roll Cage with rock bars & custom front and rear bumpers with clevis mounts. Braided brake lines, rear disc brakes, new rotors, calipers, hoses. 205 Tcase has 32 spline front and rear outputs. 20 gallon fuel cell with GM sending unit. Pictures can be sent through email PennyKenny7204@aol.com 812-442-1507 6,000. obo. Can help with delivery.
  2. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    Do you have any pictures? I would like to see it, if that isnt a problem. Thanks.
    Cory
  3. Michk5
    Michk5 1/2 ton status
    Jul 19, 2002
    139
    Misawa Japan until December...moving to Wichita Ka
  4. kvciiipenny
    kvciiipenny Newbie
    May 1, 2005
    3
    Indiana
    Cory, I need your email to send pictures
  5. DaDDyK5
    DaDDyK5 Registered Member
    Jan 4, 2001
    44
  6. 86Cucvbeater
    86Cucvbeater 1/2 ton status
    May 24, 2005
    428
    north carolina
