85 crate motor in an 86 blazer? flywheel/harmonic balancer same?
Discussion in 'The Garage' started by xtrmjoe, Aug 8, 2006.
  1. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    I priced out a crate motor for my 86 and they wanted over 2000. But the one for an 85 is only 1400. I know the rear main seals are different. So do just get a new flywheel for an 85 to? and is the harmonic balancer the same as well? Anything else I need to look out for?
    I searched a lot and did not find exactly what I was looking for 86 is a weird year new rear main seal but still carb.
  2. blazin83
    blazin83 Registered Member
    Mar 6, 2006
    18
    atlanta Ga
    if the crank is the same it should bolt up??
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    The 85-86 engine has a neutral balance harmonic balancer but the 1986 uses a different flexplate with a smaller bolt circle and it is external balanced unlike the 1985 and earlier SBC's which are internal balanced.
  4. xtrmjoe
    Aug 3, 2004
    330
    Boonville, CA
    Any engine experts have a difinitive answer I am buying this thing tomorrow?
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    If you look at my profile you'll find out i am an engine expert with 20 years professional experience.
  6. xtrmjoe
    Aug 3, 2004
    330
    Boonville, CA
    No offence I was just looking for a 2nd opinion to verify befeore I go spend a boat load of cash.
    Thanks for the advice!
    Iam getting the engine in the AM it is going to be a good weekend :)
