85 GMC jimmy master cylinder, fitting sizes?
Discussion in 'The Garage' started by cybrfire, Sep 27, 2006.
  1. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Anybody know the fitting sizes? I believe the rear line is 5/16". The front is larger but not quite 3/8". could it possibly be metric?
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Uh Oh! Problems? :o
    My line was a different size as well, ended up reusing the old fitting.
  3. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Yep! Can't quite seem to figure out the line size. I think its metric. Rear line, 5/16" threads right in but the front line, is larger but not quite 3/8".
  4. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Not possible that it's 11/32"?
  5. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    adapters..
    Many master cylinders have different "ports" than the original,and need an adapter to make the stock lines fit..I ran into this daily when I worked the parts counters..some masters have a 9/16-18 machine thread,with a flare seat,and the 1/4 line GM used factory had a fitting with larger threads than a "normal" 1/4" line has...these fittings are a pain to find ,especially on sunday..:crazy:
