85 k5 4x4
Discussion in 'The Garage' started by SueB, Nov 10, 2002.
  1. SueB
    SueB Newbie
    Oct 5, 2002
    chelsea, ok
    I have an 85 k5, wantin to add some mods, but not sure what to do . i am new to this. i want to add a 3 in lift and rn 35 tires. i want to use it for mud and a little rock crawl. as it sits it has a 305( when it dies it will be replaced with a 350) 33 in tires. what needs to be done? i know this is the place to find out everything i need to know & do. Lift, wheels & tires, anything else & sugestions??? HELP. Thanks guys.
    Sueb
  2. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    i have an 89 with 4" lift and 35's (see pics) and you may considder a 6" lift. mine rubbed under full flex, and no swaybar. i trimmed a little and it clears fine now. but i still wish i went with 6" kit. also depending on your gears, you may want to considder changing them out. my rig is a dog on the street with the 35's and 3.42's
    good luck
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Well, first off, please fill out your profile, it helps us help you. Lift, I really recomend a suspension lift over a body lift. I went 6" becouse it still left me with pleanty of mod options. To use 35" tires, you could do some fender trimming, or a lift. You do relize you'll have to regear your axles also with the larger tires I hope. I would recomened getting 3/4 Ton or 1 Ton axles, much stronger then your stock axles, and most of the time you can find them with the gears you'll need for your tire size. Welcome to CK5 /forums/images/graemlins/k5.gif
